gonesail Posted June 9, 2024 Report Share Posted June 9, 2024 is this possible? i own a 2016 edge and assumed that i could start it with the emergency key. now i am thinking not possible. Quote Link to comment Share on other sites More sharing options...
gonesail Posted June 9, 2024 Author Report Share Posted June 9, 2024 i was meaning to say start and drive the car with no key FOB .. only the emergency key. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted June 9, 2024 Report Share Posted June 9, 2024 No, it cannot be started without the fob. The fob doesn't need to work to unlock the doors with the buttons or proximity sensor, or even inside proximity sensor. There is a spot in the center console you can place the fob with the key ring forward and the buttons up to bypass the proximity if the battery is dead in the fob. Quote Link to comment Share on other sites More sharing options...
gonesail Posted June 10, 2024 Author Report Share Posted June 10, 2024 the fobs seem like a sham to me. i like having an emergency key onboard my 2011 in case i lose the other one. now it is more complicated. i am thinking an emergency fob with a power switch .. so you could hide it in the vehicle. Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 10, 2024 Report Share Posted June 10, 2024 2 hours ago, gonesail said: i am thinking an emergency fob with a power switch .. so you could hide it in the vehicle. You can hide a fob with the battery removed so the vehicle would not recognize it. Then, when needed, to start the vehicle just insert the fob (without the battery) in the backup slot in the center console and the vehicle will start and run. 2 Quote Link to comment Share on other sites More sharing options...
gonesail Posted June 10, 2024 Author Report Share Posted June 10, 2024 46 minutes ago, omar302 said: You can hide a fob with the battery removed so the vehicle would not recognize it. Then, when needed, to start the vehicle just insert the fob (without the battery) in the backup slot in the center console and the vehicle will start and run. OK thanks. sounds like a good solution. Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted June 10, 2024 Report Share Posted June 10, 2024 Take the battery out. Quote Link to comment Share on other sites More sharing options...
