fowis Posted June 6 Report Share Posted June 6 I have 2008 ford edge. I replaced the tss and oss sensors. After the replacement, the wrench light keeps coming on even at low speeds. Does the car just need more time for the relearning or there is something wrong with the replaced sensors. Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 6 Report Share Posted June 6 Read the stored error codes or get them read. Quote Link to comment Share on other sites More sharing options...
fowis Posted June 7 Author Report Share Posted June 7 1 hour ago, 1004ron said: Read the stored error codes or get them read. I am getting the same code I was getting before the sensors replacement. I get code P0715. Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 7 Report Share Posted June 7 11 hours ago, fowis said: I have 2008 ford edge. I replaced the tss and oss sensors. After the replacement, the wrench light keeps coming on even at low speeds. Does the car just need more time for the relearning or there is something wrong with the replaced sensors. 9 hours ago, fowis said: I am getting the same code I was getting before the sensors replacement. I get code P0715. So to be clear, you had the same code before and after sensor replacement. What are you using to read the codes? Quote Link to comment Share on other sites More sharing options...
garycrist Posted June 7 Report Share Posted June 7 What color is the transmission fluid? When was it changed, if ever and mileage of the Edge too? Does it shift right? Did the CEL ever go out after the parts replacement? Do you have rodent problem, as those little critters love to eat automotive wiring? Quote Link to comment Share on other sites More sharing options...
Haz Posted June 7 Report Share Posted June 7 From the 2008 Edge Workshop Manual... Relevant 2008 Edge Workshop Manual and Wiring Resource sections are attached below and in an immediately following post as PDF documents... POWERTRAIN CONTROL MODULE (PCM) - Connector C175T Location - 2008 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Connector C175T Pins-Circuits Details - 2008 Edge.pdf Main Control Valve Body - 6F50 - In-Vehicle Removal and Installation - 2008 Edge Workshop Manual.pdf Output Shaft Speed (OSS) Sensor - 6F50 - In-Vehicle Removal and Installation - 2008 Edge Workshop Manual.pdf Turbine Shaft Speed (TSS) Sensor - 6F50 - In-Vehicle Removal and Installation - 2008 Edge Workshop Manual.pdf Automatic Transmission 6F50 - Diagnostic Pinpoint Test C - TSS And OSS Sensors - 2008 Edge Workshop Manual.pdf 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 7 Report Share Posted June 7 (edited) Additional... Good luck! Powertrain Control Module (PCM) - Removal and Installation - 2008 Edge Workshop Manual.pdf 6F TRANSMISSION - Connector C168 Location - 2008 Edge.pdf 6F TRANSMISSION Controls - Wiring Diagram - 2008 Edge.pdf 6F TRANSMISSION - Connector C168 Pins-Circuits Details - 2008 Edge.pdf Solenoid Body-to-Output Shaft Speed (OSS) Sensor Internal Circuit Diagram - 6F - 2008 Edge.pdf Solenoid Body-to-Turbine Shaft Speed (TSS) Sensor Internal Circuit Diagram - 6F - 2008 Edge.pdf Edited June 7 by Haz 2 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 7 Author Report Share Posted June 7 6 hours ago, 1004ron said: So to be clear, you had the same code before and after sensor replacement. What are you using to read the codes? HT500 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 7 Author Report Share Posted June 7 1 hour ago, garycrist said: What color is the transmission fluid? When was it changed, if ever and mileage of the Edge too? Does it shift right? Did the CEL ever go out after the parts replacement? Do you have rodent problem, as those little critters love to eat automotive wiring? The transmission fluid was fine. The color was red. It looked almost new. I replaced it anyway with a new transmission fluid. Mileage is 212k. Wiring looked also fine when I replaced the sensors. What is CEL? 1 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 7 Author Report Share Posted June 7 1 hour ago, Haz said: Additional... Good luck! Powertrain Control Module (PCM) - Removal and Installation - 2008 Edge Workshop Manual.pdf 163.65 kB · 0 downloads 6F TRANSMISSION - Connector C168 Location - 2008 Edge.pdf 205.7 kB · 0 downloads 6F TRANSMISSION Controls - Wiring Diagram - 2008 Edge.pdf 96.54 kB · 0 downloads 6F TRANSMISSION - Connector C168 Pins-Circuits Details - 2008 Edge.pdf 205.27 kB · 0 downloads Solenoid Body-to-Output Shaft Speed (OSS) Sensor Internal Circuit Diagram - 6F - 2008 Edge.pdf 507.72 kB · 0 downloads Solenoid Body-to-Turbine Shaft Speed (TSS) Sensor Internal Circuit Diagram - 6F - 2008 Edge.pdf 906.99 kB · 0 downloads Thank you very much. Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 7 Report Share Posted June 7 7 minutes ago, fowis said: HT500 What app do you use with the OBD2 adapter? Quote Link to comment Share on other sites More sharing options...
garycrist Posted June 7 Report Share Posted June 7 CEL= Check engine Light or your "Wrench" icon. I dug up a video. I don't know if it helps. That is why the tranny questions. I have 210K on my 08 Edge with no problems. https://www.700r4transmissionhq.com/p0715-ford-edge/ 1 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 8 Author Report Share Posted June 8 6 hours ago, garycrist said: CEL= Check engine Light or your "Wrench" icon. I dug up a video. I don't know if it helps. That is why the tranny questions. I have 210K on my 08 Edge with no problems. After the replacement, the check engine light is always on and the wrench light comes back on as soon as I start driving the car. However, before the replacement, the check engine light and the wrench light were not coming on unless I drive on the highway above 70 mph. Thanks for the video. 1 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 8 Author Report Share Posted June 8 8 hours ago, 1004ron said: What app do you use with the OBD2 adapter? I use mobile app "Repairsol2" with this scan tool. What are the codes that you think i should get in my case? Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 8 Report Share Posted June 8 I recommend that you use Forscan Lite which should or might work with that OBDII adapter that you have - that way you'll have more confidence that all present codes are displayed. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 8 Report Share Posted June 8 Just curious if the vehicle exhibited any of the expected P0715 failure mode management symptoms beyond the Malfunction Indicator Lamp (MIL)... Good luck! 3 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 9 Author Report Share Posted June 9 Yes, I experience the following symptoms: * harsh engagement * Poor launch performance * MIL is turned on On 6/7/2024 at 12:46 PM, 1004ron said: 1 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 9 Author Report Share Posted June 9 I used also the Forscan software and I got code p0715 and code p0717. 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted June 9 Report Share Posted June 9 Time to get the volt meter out, as P0715 is an intermittent voltage loss and P0717 is FULL voltage loss. https://www.700r4transmissionhq.com/p0717-ford-edge/ 2 Quote Link to comment Share on other sites More sharing options...
fowis Posted June 13 Author Report Share Posted June 13 (edited) Voltage and resistance are checked. Harness wiring is ok. There are resistances between the transaxle connector C175T and sensors connectors so the Solenoid is also ok. There is 12 VDC at pin 2 of tss and oss connectors (Solenoid side). There is a reference voltage of 5 at pins 1 and 3 of the tss and oss connectors (Solenoid side). So, pcm is ok. Solenoid is ok Harness wiring is ok. I guess I need to replace the new installed tss and oss sensors. Edited June 13 by fowis Quote Link to comment Share on other sites More sharing options...
fowis Posted July 5 Author Report Share Posted July 5 I would like to share with you the reason for this problem. After removing the valve body I found the tss sensor is broken. During the installation, tss sensor got stuck between the valve body and transmission case. It has been pierced by the valve body and it broke as can be seen in the photo. Thank you. 1 Quote Link to comment Share on other sites More sharing options...
