eric1 Posted November 19, 2022 Report Share Posted November 19, 2022 (edited) FYI, I'm a noob and all I know is that this works specifically for the 2019 Ford Edge 2.0l Ecoboost. It could work for newer models too for all I know, but like I said, I'm a noob and all I know is that this is what works for the 2019 Ford Edge 2.0l Ecoboost. Long story short: In order to get an OEM purge valve you need to buy a whole fuel tube assembly called 'Fuel Vapour Separator Tube - 2.0l" (part number: K2GZ9D289A - link HERE) for a whopping MSRP $243.33... Read below to understand why. . . . So, every autoparts store and wesbite tells you that you need to buy this $30-40 purge valve: BUT THAT IS NOT THE RIGHT PURGE VALVE. All of the websites & mechanic systems are wrong. They say that it fits your 2019 Ford Edge 2.0l Eco boost. That's NOT true! That part is nowhere to be found in your car. The purge valve that you need for your 2019 Ford Edge 2.0l Ecoboost looks like this: However, it appears that Ford does not sell this purge valve individually. You cannot buy an OEM version of this purge valve online. You can buy cheap Chinese versions online, but I guarantee you that they will last no more than 3 months at best. I'd highly advise staying away from that junk. The only way to get an OEM purge valve for your 2019 Ford Edge 2.0l Ecoboost is to buy a 'Fuel Vapour Separator Tube - 2.0l" (part number: K2GZ9D289A - link HERE).. This is what that looks like: Unfortunately, this whole assembly costs MSRP: $243.33. On the website if you change the dealer you're purchasing from you can maybe find it for a lower price. I selected a dozen different dealers & I was fortunate enough to find a dealer selling it for $175.20. Once you purchase that and receive it, just replace the whole Fuel Vapour Separator Tube and you'll be good. It's super easy to replace. If you need a guide on how to replace it, use this link Now, if you're okay with all of that, then you should be good to go. You're done and that's all you need to do. Hope this helps. However, if you want to save like $50+, then I have another solution that might work. I'm a car noob, so I don't know if it'll work. I did not do this nor attempt it. It's just a thought. Please do not take this as advice. It's just a thought: You could buy the Fuel Vapour Separator Tube that fits 2015-2018 Ford Edge models and then cut out the purge valve from the tube and throw the tube away. That part number is F2GZ9D289A (MSRP: $176.67) You'll then have to take your Fuel Vapour Separator Tube out of your 2019 Ford Edge 2.0l ecoboost and cut your purge valve out, then replace it with the purge valve you just got from the 2015-2018 Fuel Vapour Separator Tube. Once you put the new purge valve in your original Fuel Vapour Separator Tube just reinstall it back in and you'd be good. Again, I have not done this. I'm a car noob and know nothing about cars. I just thought this could maybe work. Only attempt this if you know what you're doing. NOTE: The 2015-2018 Fuel Vapour Separator Tube looks very similar to the 2019 Fuel Vapour Separator Tube, but they are NOT the same. Do not try to use the tubes from the 2015-2018 Fuel Vapour Separator Tube, only try and use the purge valve from it. Edited November 21, 2022 by eric1 Quote Link to comment Share on other sites More sharing options...
nate39 Posted June 2 Report Share Posted June 2 Hi, I need a purge valve, I think it is also known as a fuel valve separator, for a 2020 edge 2.0 engine. I am having a very difficult time trying to find one online. It will have to include all the hoses. the dealer wants 330.00 for one which is robbery. any help? thanks 1 Quote Link to comment Share on other sites More sharing options...
atulo Posted June 2 Report Share Posted June 2 (edited) Tube Assembly Fuel Vapour Separat - Ford (K2GZ-9D289-A) https://www.fordpartscatalog.com/oem-parts/ford-tube-assembly-fuel-vapour-separat-k2gz9d289a Edited June 3 by atulo 1 Quote Link to comment Share on other sites More sharing options...
nate39 Posted June 3 Report Share Posted June 3 thanks, there is no picture and that part number sometimes comes up for the wrong part. How sure are you this is the right one? when I put my car model in I have to look up the part and can never find it at that point. Quote Link to comment Share on other sites More sharing options...
atulo Posted June 3 Report Share Posted June 3 (edited) I noted down that part number from another thread a while ago. I did that in case I will need it. The picture is shown up here: https://parts.ford.com/shop/en/us/fuel-system/fuel-chassis/fuel-vapour-separator-tube-p-f2gz9d289a?pdp=y Edited June 3 by atulo 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 3 Report Share Posted June 3 As @atulo indicates, with this result from using VIN from a 2020 Edge Titanium 2.0L EcoBoost... Relevant sections from the 2020 Edge Workshop Manual are attached below as PDF documents... Good luck! Evaporative Emission Canister Purge Valve - 2.0L EcoBoost - Removal and Installation - 2020 Edge Workshop Manual.pdf Quick Release Coupling - 2.0L EcoBoost - Removal and Installation - 2020 Edge Workshop Manual.pdf 2 Quote Link to comment Share on other sites More sharing options...
nate39 Posted June 3 Report Share Posted June 3 9 hours ago, Haz said: As @atulo indicates, with this result from using VIN from a 2020 Edge Titanium 2.0L EcoBoost... Relevant sections from the 2020 Edge Workshop Manual are attached below as PDF documents... Good luck! Evaporative Emission Canister Purge Valve - 2.0L EcoBoost - Removal and Installation - 2020 Edge Workshop Manual.pdf 692.12 kB · 2 downloads Quick Release Coupling - 2.0L EcoBoost - Removal and Installation - 2020 Edge Workshop Manual.pdf 3.51 MB · 2 downloads This is not the right one which is why all this is confusing. I bought this one and it would work but the hose from the valve to the split is way too short. if you search using this part on Ebay for instance you can find one that has the longer hose that I am pretty sure that works but even the Ford dealer mechanics I think can be confused. Here is a link to one I think works, https://www.ebay.com/itm/266747977737?epid=23066424568&itmmeta=01HZF2Q91NPR668D15HS82Y7EF&hash=item3e1b6b2009:g:idIAAOSwlWdmCwTO&itmprp=enc%3AAQAJAAAAwIPgv%2F9Y77ImVkxz%2BKlcOC03XILTRhBEpk5Z6gqCU%2B6LKD6%2FJAHSPqP9y2O0HBNQSU%2BO6ihLJJRnME0Sr28rwKuy%2BmjWzWiE%2BTbN1UlVmdW7C0uxi8eTOLqqbfUE8M45trt102CG3%2FjSbYnlxoff8tJNTHbyh55BnibpkYg5oOIXeFJQ15sCh%2BVBtDy1CRqRVj%2FmxyJYo3JgQGyRWHcbmvJLudGVscU5ap%2FcuTKLHhdFcwdaoNtOLmKuf7qOZg9wjA%3D%3D|tkp%3ABk9SR46R3eL7Yw Quote Link to comment Share on other sites More sharing options...
nate39 Posted June 3 Report Share Posted June 3 10 hours ago, atulo said: I noted down that part number from another thread a while ago. I did that in case I will need it. The picture is shown up here: https://parts.ford.com/shop/en/us/fuel-system/fuel-chassis/fuel-vapour-separator-tube-p-f2gz9d289a?pdp=y this link goes nowhere, sorry 2 Quote Link to comment Share on other sites More sharing options...
nate39 Posted June 3 Report Share Posted June 3 The guy from the link above to Ebay confirmed that will fit so I ordered it. It can be returned but I am pretty sure that will work. You can see the difference with the picture above, thanks for the help Quote Link to comment Share on other sites More sharing options...
Dai505 Posted June 6 Report Share Posted June 6 (edited) Do need to correct myself. Received the part form Rock Auto. It's not the same. The connectors are different. Still hunting for the right one. Edited June 8 by Dai505 3 Quote Link to comment Share on other sites More sharing options...
nate39 Posted June 20 Report Share Posted June 20 (edited) On 6/6/2024 at 5:23 PM, Dai505 said: Do need to correct myself. Received the part form Rock Auto. It's not the same. The connectors are different. Still hunting for the right one. The link I posted above works fine for my 2020 Edge. Also, the one pictured at the beginning of this thread is the correct one. I got a genuine Ford one for 100 bucks on Ebay. You need the one with the longer, flexible hose from the valve to the split. The stiff double bend hose will not work. also, I detached the yellow connection hose and just kept the old one. This saved me some time since getting the valve off was about a thirty minute pain. Edited June 20 by nate39 Quote Link to comment Share on other sites More sharing options...
