Key fobs on same key chain, won't work otherwise
I have a well taken care of 2012 Ford Edge and it came with 2 key fobs. They are on the same key ring. From the get go only one fob works. I have a circle painted on the back with nail polish to know which is which. If I removed the non working key fob from the key ring, the working one stops working. It would be really nice to have two separate fobs to use. Any ideas? Thank you.
So you have the IKT (key with a cut blade and all the remote features on the head) and have to turn the key to start. You have one that electronically works (when near the steering column), and one that physically turns the ignition switch, but neither key will do both? Or only one works to remotely lock/unlock, but both will start the car?
Or do you have push to start and Intelligent Access?
