Ford Power Up (sync 4 update)
  • hanoudi changed the title to Ford Power Up (sync 4 update)
My 22ST has Sync Power Up version 4.2.4.  My car is in the garage at the house most of the time and I know it connects to my wifi when I get in my driveway.  I remember the last update was at least a couple of months ago.  If you connect to your home wifi, you can go to the settings, I think software updates, and when I do that it manually checks for updates each time.
Thank you. My 22ST is definately behind. It is connected to my wifi in the garage but never received the update. If check for updates it says nothing is available.
I will take it to the dealer to see if they can update it.
