Jace Posted May 13 Report Share Posted May 13 I have a 2011 ford edge. In the center console, I have a single 3.5mm aux Jack input that is separate from a single car cig lighter power output jack. Can these be replaced with a better power output and/or input? Can these replaced with a USB port or something similar/upgraded? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted May 13 Report Share Posted May 13 If you have an AUX in, you have MyFord which doesn't have USB or Bluetooth capabilities, so a USB port wouldn't provide any benefit. Any power point to USB power adapter will provide much better power than the USB standard of 500mW to charge. To have a setup that can play songs from a USB thumb drive, or apps on a phone, or Apple CarPlay or Android Auto, you would need to go with an aftermarket head unit. The MyFord Touch 8 inch touch screen available for your year would have Bluetooth and USB drive playing capabilities, but would be as much work as an aftermarket setup. I don't know if center console replacements to fit a touch screen are common or available for your year and no touchscreen already. Quote Link to comment Share on other sites More sharing options...
Haz Posted May 14 Report Share Posted May 14 Relevant wiring diagrams and electrical connector info, attached below as PDF documents... Good luck! Premium Audio without SYNC with Aux Audio Input Jack - Wiring Diagram - 2011 Edge.pdf Premium Audio without SYNC with Aux Audio Input Jack - Connector C3312 Location - 2011 Edge.pdf SYNC equipped, with Media Hub - Wiring Diagram - 2011 Edge.pdf Power Points - Wiring Diagram - 2011 Edge.pdf Premium Audio without SYNC with Aux Audio Input Jack - Connector C3312 Pin-Circuit Details - 2011 Edge.pdf Quote Link to comment Share on other sites More sharing options...
