Edd Posted May 12, 2024 Report Share Posted May 12, 2024 I've just purchased a 2024 Ford Edge (Titanium trim level). According to everything I have read I should have Sync 4A. I have the larger, vertical screen and everything seems to work fine. However, it appears that the system is not 4a, just Sync 4. Am I missing something? Thanks. Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted May 12, 2024 Report Share Posted May 12, 2024 Not sure if this will help. https://www.ford.com/support/how-tos/sync/getting-started-with-sync/what-are-sync-4-and-sync-4a/ Check your build date, maybe the system upgrade is only on later built vehicles. Quote Link to comment Share on other sites More sharing options...
Will2U Posted May 12, 2024 Report Share Posted May 12, 2024 You should have 4A. Consult your window sticker. You should also have "cards" above climate control that display recently used apps. I noticed on mine that the "about sync" screen just says Sync 4 but it is 4A functionality. Quote Link to comment Share on other sites More sharing options...
Edd Posted May 15, 2024 Author Report Share Posted May 15, 2024 Were personal profiles removed in the latest software? My 2024 Edge does not seem to have them. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted May 16, 2024 Report Share Posted May 16, 2024 My 2021 doesn’t want to update. It’s behind on sync updates. I don’t have any of the apps or games. I only have the basic stuff and the drawing app. It always shows that no updates are available. Quote Link to comment Share on other sites More sharing options...
