EdgeGirl21 Posted May 11, 2024 Report Share Posted May 11, 2024 Hello, so as the title states, I have a 2018 edge titanium, 137000 miles. And I've gotten 3 codes. The first code was my wastegate. I know that the pump needs to be changed. And I haven't had it changed but now because the wrench icon showed up on my dash. Had the codes ran & I was told that I need a transmission. Took to the Ford dealership, and yes, of course, they said that I need a transmission and the cost us outrageous. But I was wondering if I changed or had that wastegate pump changed would that correct any potential transmission solenoid issues Quote Link to comment Share on other sites More sharing options...
MEwhyeventry Posted October 19, 2024 Report Share Posted October 19, 2024 Have the vacuum pump tested and the wastegate solenoid tested, if they’re bad replace them. Then see if that solves your problem. It very well might if either one of those parts are bad. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 29 Report Share Posted January 29 What were the transmission codes? (Do you hot rod the car, or tow heavy boat?) Quote Link to comment Share on other sites More sharing options...
