tuxnet Posted May 3 Report Share Posted May 3 (edited) Hello, I own a 2014 Limited and have begun to experience issues with the ABS, ACC, and AdvanceTrac systems. I replaced the battery, no luck. I ran Forscan test and here are the results (I removed the items without DTC's): ===PCM DTC P193C:00-2C=== Code: P193C - Steering Wheel Angle Signal Status (-2C): - DTC Maturing - Intermittent at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Powertrain Control Module ===END PCM DTC P193C:00-2C=== ===C-CM DTC U0418:68-2C=== Code: U0418 - Invalid Data Received from Brake System Control Module 'A' Additional Fault Symptom (:68): - Event Information Status (-2C): - DTC Maturing - Intermittent at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Cruise-Control Module Freeze Frame #1: -EVENT_TIME: 306010067 s (Tue Apr 16 19:14:58 2024) - Event time -IFC_D703: 0 - Internal Module Fail Code ===END C-CM DTC U0418:68-2C=== ===ABS DTC U3000:49-68=== Code: U3000 - Control Module Additional Fault Symptom (:49): - Internal Electronic Failure Status (-68): - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC - Test not complete Module: Antilock braking system Freeze Frame #1: -EVENT_TIME: 305918886 s (Mon Apr 15 17:55:17 2024) - Event time -POWER_MODE: Running - Power Mode Status -ABS: Inactive - ABS -AYC: Inactive - AYC -BTCS: Inactive - BTCS -201D -HDC: Inactive - HDC -RSC: Inactive - RSC -BTC: Inactive - BTC -VAC_BST_ST: Inactive - Active Vacuum Booster State -BST_REL_SW: Inactive - Booster Release Switch State -HYD_PMP_ST: Inactive - Hydraulic Pump State -ECU_POWER_SUPPLY: 13.9 V - ECU Power Supply Voltage -VSS: 5.0 km/h - Vehicle Speed ===END ABS DTC U3000:49-68=== ===IPC DTC U0131:00-2F=== Code: U0131 - Lost Communication With Power Steering Control Module 'A' Status (-2F): - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Panel Control Module ===END IPC DTC U0131:00-2F=== ===IPC DTC U045A:56-2F=== Code: U045A - Invalid Data Received From Parking Assist Control Module A Additional Fault Symptom (:56): - Invalid/Incompatible Configuration Status (-2F): - DTC Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Instrument Panel Control Module ===END IPC DTC U045A:56-2F=== The malfunction of the ABS control module is evidently causing erratic behavior in other systems. I visited a Ford Dealership, where they suggested replacing the module (Part number: DT4Z2C405F) for a substantial fee. My research revealed that this module consists of two components: the Hydraulic part (DT4Z2C215A) and the Electronic part (DT4Z2C219B). Since the brakes are functioning properly, I am considering replacing only the ECU part, especially since the DCU reading from Forscan indicates an Internal Electronic Failure, which suggests that replacing just the ECU might suffice. The dilemma is whether I can replace just the ECU or if I need to replace both components. Any additional advice would be highly valued. Edited May 3 by tuxnet Quote Link to comment Share on other sites More sharing options...
tuxnet Posted May 7 Author Report Share Posted May 7 Come on guys, need a hand! Quote Link to comment Share on other sites More sharing options...
Haz Posted May 8 Report Share Posted May 8 (edited) Welcome to the Forum, @tuxnet! From the 2014 Edge Workshop Manual... As indicated above, if your Edge is not equipped with Adaptive Cruise, then you may replace only the ABS Module. However, if your Edge is equipped with Adaptive Cruise, then the ABS/HCU is serviced as one unit. Replacing the ABS Module will require your Edge's As-Built ABS Module data to be programmed into the new replacement ABS Module. Due to the indicated internal failure of the ABS Module , you will likely be unable to access that data in your Edge's current ABS Module. Click on this link to the Ford Service site, select Country/Language pick list values, then enter your Edge's VIN and the Security Check value. ABS Module As-Built values are contained in the Line 760 address entries of your VIN query results... Relevant Workshop Manual sections are attached below as PDF documents... Good luck! Anti-Lock Brake System (ABS) Module - Removal and Installation - 2014 Edge Workshop Manual.pdf Hydraulic Control Unit (HCU) - Removal and Installation - 2014 Edge Workshop Manual.pdf Hydraulic Control Unit (HCU) - Enhanced Illustration - 2014 Edge Workshop Manual.pdf Anti-Lock Brake System (ABS) Module - Enhanced Illustration - 2014 Edge Workshop Manual.pdf Intake Air System Components — Exploded View - Removal and Installation - 2014 Edge Workshop Manual.pdf Quick Connect Coupling - General Procedures - 2014 Edge Workshop Manual.pdf Battery and Battery Tray — Exploded View - Removal and Installation - 2014 Edge Workshop Manual.pdf Battery and Battery Tray — Exploded View - Enhanced Image - 2014 Edge Workshop Manual.pdf Brake System Bleeding - General Procedures - 2014 Edge Workshop Manual.pdf Edited May 8 by Haz 1 1 Quote Link to comment Share on other sites More sharing options...
tuxnet Posted May 15 Author Report Share Posted May 15 Hello @Haz, I was unable to find the part requested by the dealership because it seems to be on backorder. The ABS module part number for my car is DT43-2C405-EB. While there are only two parts with that exact number on eBay, there are several others that might be suitable, although the last two letters vary. OEM 2011-2014 FORD EDGE Lincoln MKX ABS Anti Lock Pump Assembly DT43-2C405-DA | eBay 2011-2014 FORD EDGE LINCOLN MKX ABS Pump Assembly ANTI-LOCK MODUL DT43-2C405-DB | eBay Quote Link to comment Share on other sites More sharing options...
Haz Posted May 16 Report Share Posted May 16 (edited) I regret that I cannot offer any clarity on the part differences between suffixes EB / DA /DB. Perhaps the part number your dealer was seeking is... Link to this ABS Control Unit - DT4Z-2C405-F - 2014 Ford Edge - FordParts online listing Link to this ABS Control Unit - DT4Z-2C405-F - 2014 Ford Edge - AutoNation Parts online listing Neither source explicitly indicates the part is on Backorder. Good luck! Edited May 16 by Haz 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted May 16 Report Share Posted May 16 (edited) . Edited May 16 by Wubster100 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted May 16 Report Share Posted May 16 (edited) Edit: removed my comment because it isn’t helpful. Edited May 16 by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
tuxnet Posted June 18 Author Report Share Posted June 18 Hello everyone, I'm excited to share an update: I've successfully purchased the DT43-2C405 part from eBay. A local mechanic and I determined that the last two letters signify a version of the part. As it happens, any DT43-2C405 part is compatible. After the mechanic installed and programmed the new part, all the Diagnostic Trouble Codes (DTC) and warning lights on the dashboard were cleared. The mechanic also changed the brake fluid and performed a brake bleed. Now, everything is functioning as it should. 1 1 Quote Link to comment Share on other sites More sharing options...
Ryan UK Edge 2017 Posted October 4 Report Share Posted October 4 On 5/8/2024 at 1:06 AM, Haz said: Welcome to the Forum, @tuxnet! From the 2014 Edge Workshop Manual... As indicated above, if your Edge is not equipped with Adaptive Cruise, then you may replace only the ABS Module. However, if your Edge is equipped with Adaptive Cruise, then the ABS/HCU is serviced as one unit. Replacing the ABS Module will require your Edge's As-Built ABS Module data to be programmed into the new replacement ABS Module. Due to the indicated internal failure of the ABS Module , you will likely be unable to access that data in your Edge's current ABS Module. Click on this link to the Ford Service site, select Country/Language pick list values, then enter your Edge's VIN and the Security Check value. ABS Module As-Built values are contained in the Line 760 address entries of your VIN query results... Relevant Workshop Manual sections are attached below as PDF documents... Good luck! Anti-Lock Brake System (ABS) Module - Removal and Installation - 2014 Edge Workshop Manual.pdf 158.86 kB · 6 downloads Hydraulic Control Unit (HCU) - Removal and Installation - 2014 Edge Workshop Manual.pdf 475.48 kB · 5 downloads Hydraulic Control Unit (HCU) - Enhanced Illustration - 2014 Edge Workshop Manual.pdf 328.11 kB · 3 downloads Anti-Lock Brake System (ABS) Module - Enhanced Illustration - 2014 Edge Workshop Manual.pdf 126.44 kB · 3 downloads Intake Air System Components — Exploded View - Removal and Installation - 2014 Edge Workshop Manual.pdf 561.46 kB · 2 downloads Quick Connect Coupling - General Procedures - 2014 Edge Workshop Manual.pdf 631.63 kB · 2 downloads Battery and Battery Tray — Exploded View - Removal and Installation - 2014 Edge Workshop Manual.pdf 215.83 kB · 2 downloads Battery and Battery Tray — Exploded View - Enhanced Image - 2014 Edge Workshop Manual.pdf 101.6 kB · 1 download Brake System Bleeding - General Procedures - 2014 Edge Workshop Manual.pdf 722.4 kB · 4 downloads Hi Haz ivr joined the forum as I’ve just got a new to me ford edge and have just read this I can’t believe the knowledge you have shared and the documentation you have uploaded it’s close to my fault if you have any spare time could I share my issue please cheers ryan Quote Link to comment Share on other sites More sharing options...
Ryan UK Edge 2017 Posted October 4 Report Share Posted October 4 On 6/18/2024 at 2:59 PM, tuxnet said: Hello everyone, I'm excited to share an update: I've successfully purchased the DT43-2C405 part from eBay. A local mechanic and I determined that the last two letters signify a version of the part. As it happens, any DT43-2C405 part is compatible. After the mechanic installed and programmed the new part, all the Diagnostic Trouble Codes (DTC) and warning lights on the dashboard were cleared. The mechanic also changed the brake fluid and performed a brake bleed. Now, everything is functioning as it should. Amazing outcome 👍 1 Quote Link to comment Share on other sites More sharing options...
Ryan UK Edge 2017 Posted October 4 Report Share Posted October 4 Did you replace just the one part or both in the end 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 11 hours ago Report Share Posted 11 hours ago On 5/7/2024 at 8:06 PM, Haz said: However, if your Edge is equipped with Adaptive Cruise, then the ABS/HCU is serviced as one unit. @HazDo you have more information on this for 2019-2024? Can the ECU be separated? Quote Link to comment Share on other sites More sharing options...
tuxnet Posted 11 hours ago Author Report Share Posted 11 hours ago On 10/4/2024 at 4:26 PM, Ryan UK Edge 2017 said: Did you replace just the one part or both in the end Both parts, ECU and Hydraulic. But bought together as a single unit. 1 Quote Link to comment Share on other sites More sharing options...
