St Driver 21 Posted May 3 Report Share Posted May 3 Looking for the correct color of a remote turn on wire for LOC. Trying to install aftermarket amp. Quote Link to comment Share on other sites More sharing options...
sc00by Posted June 22 Report Share Posted June 22 (edited) In this thread https://www.fordedgeforum.com/topic/28586-audio-build-in-2019-edge-st/#comment-210300, the OP is using an Audio Control LC2i Pro. If you zoom in on the image of the LOC, you will note there is no remote wire used on the LOC. This loc has three different methods to turn on, one of which is using an audio signal so the remote wire isn't needed to turn on the LOC, and the LOC provides a remote turn on terminal for an amp. More than likely, I will be using the same LOC but part of me wants a traditional remote wire. It could be possible to use one of those add-a-fuse https://www.amazon.com/gp/product/B0827L4HH9/ and piggy back off of something in the fuse box for an ignition switch option. You would need to run a wire from the fuse block up front to the rear of the car. The fuse box would need to be modified to allow this wire to pass through the lid which may not be desirable. Edited June 22 by sc00by Quote Link to comment Share on other sites More sharing options...
