Jonnymerk Posted May 2, 2024 Report Share Posted May 2, 2024 I am looking for a solution to fix an issue with the rear diff stock rubber bushings. I lowered my edge with H&R springs and the Bilstein shocks. The performance shop I use had to install a set of aftermarket adjustable rear camber arms to bring the rear back into spec. I've been getting a clunk and rattle now under load that the shop believes is attributed to movement and shifting of the rear diff and the one of the adjustable camber arms making contact. Shop believes upgraded diff bushings like polyurethane could solve the problem. Has anyone else had similar issues when lowering? Anyone have any idea who or where I can find said bushings? For reference pic of added part attached. I was unaware these would be needed to get the camber in spec with the H&R/Bilstein combo. Quote Link to comment Share on other sites More sharing options...
Jonnymerk Posted May 10, 2024 Author Report Share Posted May 10, 2024 Bump does anyone know of a replacement urethane bushing for the rear differential?! Quote Link to comment Share on other sites More sharing options...
