Optimus Posted May 1, 2024 Report Share Posted May 1, 2024 Hi, I have ford Edge 2013 sports, the problem is when i turn off the engine and lock the car the Sony screen does not go off, i have to open the passenger door once and close it then the screen goes into clock mode and turns off when i lock the car. But every time i have to open & close passenger door for this. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 14, 2024 Report Share Posted May 14, 2024 Does the interior lights dim and go off when opening & closing the drivers door? (Thinking one possibility may be the drivers door closed switch had failed open and either disconnected, or had failed closed.) Believe both doors are wired in parallel. Opening either should kill the audio control unit. Quote Link to comment Share on other sites More sharing options...
Optimus Posted May 15, 2024 Author Report Share Posted May 15, 2024 Hi, Nothing happens when i open or close the driver door, nor i get door open sign in the info meter, seems like that sensor is dead. But when i open al other 3 doors i get the door open sign and opening passenger door immediately kill the audio unit but nothing happens with driver door. Quote Link to comment Share on other sites More sharing options...
Mdnm89 Posted August 28, 2024 Report Share Posted August 28, 2024 Sounds like the drivers door ajar switch is bad. May get lucky and just have to replace the ajar switch rather than the whole latch. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 22, 2025 Report Share Posted March 22, 2025 You ever fix this? Quote Link to comment Share on other sites More sharing options...
ford07 Posted June 2, 2025 Report Share Posted June 2, 2025 If that doesn't change anything, you'll probably need to look at the electrical installation to make sure that the screen is powered by "ACC" and not "constant". Quote Link to comment Share on other sites More sharing options...
