Wubster100 Posted August 26, 2024 Author Report Share Posted August 26, 2024 I am using SW-8183 (DG9Z-9C888-GC) This does not have lane centering. It has a LIM button but I haven't enabled it or tried to use it. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted August 26, 2024 Report Share Posted August 26, 2024 What code number did you use in the SCCM to activate it. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 4, 2024 Author Report Share Posted September 4, 2024 @johnmarkpI am using option 20 - Ford ASLD+ACC Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted November 24, 2024 Author Report Share Posted November 24, 2024 I have a confirmation that you must replace the ABS module to one that supports CADSIII for lane centering to work. 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted November 24, 2024 Report Share Posted November 24, 2024 Interesting. Does this also make it Stop and Go ACC? How much programing did you have to do. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted November 24, 2024 Author Report Share Posted November 24, 2024 For 2019-2020 Edge, you must disconnect the brake lines and replace the entire abs module. Then you need to enter your VIN number and complete the ABS calibration. This can all be done using FORScan. Stop and go, lane centering, and evasive steering assist all work. For 2021-2024 Edge, more information is still needed because PATS immobilizer could be part of the ABS module. FORScan does not currently support ABS service functions or PATS service functions for 2021-2024 Edge. I am going to order an ABS module for my 2021. 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted November 24, 2024 Report Share Posted November 24, 2024 This gives me a lot to think about. The ABS module is not that expensive. Putting it in would be a pain on my bad back. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 9 Author Report Share Posted January 9 I have not given up yet. I have an ABS module to install once the weather gets warmer. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted January 9 Report Share Posted January 9 @johnmarkp: From the 2019 Edge Workshop Manual, attached below as PDF documents... Good luck! Hydraulic Control Unit (HCU) - Removal and Installation - 2019 Edge Workshop Manual.pdf Anti-Lock Brake System (ABS) Module - Removal and Installation - 2019 Edge Workshop Manual.pdf 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 10 Author Report Share Posted January 10 I will also have to bleed the brakes. brake%20system%20bleeding.pdf Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 18 Author Report Share Posted January 18 A few updates to the cruise control project: 1. I have not replaced the lower front bumper cover trim to one that protects the cruise control module. So far, no damage or sensor blockage has occurred. I was able to use adaptive cruise control in the rain. I did not notice any snow or dirt accumulate on the sensor. 2. The ABS module will need to be replaced for lane centering, evasive steering assist, and ACC to 0 mph. I have received an ABS module. Currently, FORScan does not have any ABS service functions for the 2021-2024 Edge. However, the FORScan Team has sent me a test build, so I should be able to calibrate the ABS module and bleed the brakes. Hopefully I will be able to find time to replace the ABS module and bleed the brakes soon. 3. A little while ago, my ACC and pre collision assist stopped working. The cause of this problem was a poor connection (done by me lol). The CCM was only getting about 8 volts of power. The solution to this was to fix my bad wiring and ensure the CCM communication wires are a twisted pair. 4 Quote Link to comment Share on other sites More sharing options...
juanolga Posted Friday at 03:58 PM Report Share Posted Friday at 03:58 PM Hi, I'm hoping you can help me. I installed a used CCM module from another vehicle to activate ACC. However, my problem is that when I log into Forscan, the CCM module doesn't appear in my vehicle's configuration like the other modules do, and I can't calibrate it. It's installed correctly. Is there anything I need to do to get Forscan to recognize it in my vehicle's configuration? Thanks. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Friday at 04:41 PM Author Report Share Posted Friday at 04:41 PM Welcome to the forum @juanolga, When you start FORScan and connect to the vehicle, do not select a profile. Allow FORScan to create a new profile to scan for new modules. 2 Quote Link to comment Share on other sites More sharing options...
juanolga Posted Friday at 10:02 PM Report Share Posted Friday at 10:02 PM Thank you very much for your help. I connected Forscan as you told me, and it did recognize the module. Thank you very much for your help. Regards 1 Quote Link to comment Share on other sites More sharing options...
