hale232 Posted April 23, 2024 Report Share Posted April 23, 2024 Please help, and sorry for bed english.... I'm from Croatia.... is it normal for you that when it's a little colder outside... that the car doesn't start at first.... the other day when it was 3C degrees, it misfired 2-3 times and only the first time in the morning, later in during the day it lights up... it is strange to me that when it is turned on in the morning it shows that the outside temp is 87C. battery health is 80%, capacity 75%, voltage about 12.4V... the mechanic says it's ok. the car otherwise works perfectly, pulls, doesn't smoke.. it is 2.0 154KW video: https://youtube.com/shorts/LboaCADX_qA?feature=share Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 23, 2024 Report Share Posted April 23, 2024 "in the morning it shows that the outside temp is 87C" - get the intake air temperature sensor checked and replaced if needed - this will make cold starts harder. Get the stored error codes read. 1 Quote Link to comment Share on other sites More sharing options...
