2013 Edge Limited staying on after radio swap
I have 2013 Edge limited with Sync 2.  I had removed the old radio and installed an Autotec aftermarket radio.  After connecting everything I noticed my car will not turn off.  It keeps running even after I remove the key.  In order to turn off the car I had to disconnect the battery.  When I reconnect the battery the car turns on with no key in the ignition like it thinks the key is in the on position.  Hitting the brakes, turn the key, lock unlock on the fob is not working.  This is such an od ball problem.
