Pump Posted April 16, 2024 Report Share Posted April 16, 2024 Used Turtle Wax Hybrid Solutions Ceramic Spray Coating on 2020 Titanium and I'm pleased with the results. However I messed up on a section of the passenger door as you can see in the photo. The streaking is caused by applying too much spray and not wiping it down. Please offer suggestions on how to remove the streaks. (Sent photo to Turtle Wax but no response yet.) Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted April 16, 2024 Report Share Posted April 16, 2024 (edited) Don't worry, since ceramic and wax sits on the surface, you haven't damaged the clear coat or paint, but you will need to remove the ceramic coating. I'd check online to see if there are proven techniques and solutions specific to removing ceramic coating. The best way I've found to remove old wax is to wash the car with Dawn or another detergent that breaks down grease, then clay bar the car, wash and apply wax or ceramic. If you want to do just the affected area, try a clay bar on a small area. Of course, never use Dawn to regularly wash the car. Good luck. Edited April 16, 2024 by Tim W. AZ Quote Link to comment Share on other sites More sharing options...
bscott94 Posted April 18, 2024 Report Share Posted April 18, 2024 I would try a wash and hand polish. I use mostly Adam's Polishes and have used this product before so that's my suggestion. Any light polish should work though. https://adamspolishes.com/products/adam-s-revive-fine-hand-car-polish?_pos=1&_sid=25c2bdc8d&_ss=r Quote Link to comment Share on other sites More sharing options...
