RobsEdge Posted April 13, 2024 Report Share Posted April 13, 2024 Good day folks! I'm looking to verify alternative tire sizes for my 2018 Ford Edge Sport. Stock is 265/40R21, but would a 255/45R21 or 275/45R21 work? I tried the search method but came up with no results. I'm trying to increase my options for tires in hopes of finding a more cost-effective replacement that will fit with the sport trim. Thanks in advance for any help, it is appreciated. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 13, 2024 Report Share Posted April 13, 2024 Try this site to assess the difference https://www.willtheyfit.com/index.php?width=265&aspect=40&diameter=21&wheelwidth=9&offset=55&width2=255&aspect2=45&wheel_size=21&wheel_width=9&offset2=55 The 275's would result in a ride height/circumference change that I wouldn't like, but would probably still work. https://www.willtheyfit.com/index.php?width=265&aspect=40&diameter=21&wheelwidth=9&offset=55&width2=275&aspect2=45&wheel_size=21&wheel_width=9&offset2=55 https://www.wheel-size.com/size/ford/edge/2018/ 2 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted April 13, 2024 Report Share Posted April 13, 2024 here's an option from an older thread 2 Quote Link to comment Share on other sites More sharing options...
RobsEdge Posted April 14, 2024 Author Report Share Posted April 14, 2024 On 4/13/2024 at 2:56 AM, 1004ron said: Try this site to assess the difference https://www.willtheyfit.com/index.php?width=265&aspect=40&diameter=21&wheelwidth=9&offset=55&width2=255&aspect2=45&wheel_size=21&wheel_width=9&offset2=55 The 275's would result in a ride height/circumference change that I wouldn't like, but would probably still work. https://www.willtheyfit.com/index.php?width=265&aspect=40&diameter=21&wheelwidth=9&offset=55&width2=275&aspect2=45&wheel_size=21&wheel_width=9&offset2=55 https://www.wheel-size.com/size/ford/edge/2018/ Thank you, I will use this to help figure things out. I will report back if I go with a different-sized tire. 1 Quote Link to comment Share on other sites More sharing options...
