bhamraS97 Posted April 8, 2024 Report Share Posted April 8, 2024 (edited) Hi All, I added the DRL menu to my edge left digital screen. I changed these values below https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true And enabled the menu for IPC(via non-asbuilt menu) using forscan. Now the thing is, the menu is there, I can toggle the menu but it does not turn on the DRL, the DRL stays off. Any idea what I am missing? Edited April 8, 2024 by bhamraS97 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted April 8, 2024 Report Share Posted April 8, 2024 What model and options, and what are you expecting to be used as the DRL? SEL or higher has the LED signature lighting triangles on the bumper, SE comes standard with configurable DRL in the US. Quote Link to comment Share on other sites More sharing options...
bhamraS97 Posted April 8, 2024 Author Report Share Posted April 8, 2024 Mine is a SEL and has LED Signature lighting (those triangle one on the bumper). In Canada, we do not have configurable DRL option. Currently, my car has low beams as DRL along with the signature LED triangles. I tried enabling the functionality for configurable DRL via settings. However, after changing the mentioned things on forscan, I got the menu and can toggle the menu but the toggling does nothing. The DRL(low beam) would remain off Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 8, 2024 Report Share Posted April 8, 2024 2 hours ago, bhamraS97 said: Mine is a SEL and has LED Signature lighting (those triangle one on the bumper). In Canada, we do not have configurable DRL option. Currently, my car has low beams as DRL along with the signature LED triangles. I tried enabling the functionality for configurable DRL via settings. However, after changing the mentioned things on forscan, I got the menu and can toggle the menu but the toggling does nothing. The DRL(low beam) would remain off The DRL only works when in Drive or Reverse, not sure about Neutral. So you have to check it while it is in gear. Also, when the DRL is set to be configurable, as you have done now, the head light switch must be in "Auto". 1 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted April 8, 2024 Report Share Posted April 8, 2024 Turned on in the information display (what you enabled to see) Ignition on Not in park Light switch set to Auto lamp (this is different from non-configureable in that it would also do it in Off and Parking Lamps) Headlamps are off (so in Auto but dark enough to turn them on) 1 1 Quote Link to comment Share on other sites More sharing options...
bhamraS97 Posted April 8, 2024 Author Report Share Posted April 8, 2024 Thanks @omar302@dabangsta Will try your suggestions Quote Link to comment Share on other sites More sharing options...
bhamraS97 Posted April 9, 2024 Author Report Share Posted April 9, 2024 Another question, I just realized the RPM display that shows up on the right side seem to be removed This small image from internet for reference. It still has the proper big RPM display but that small one on the right is missing. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 9, 2024 Report Share Posted April 9, 2024 (edited) You need to change the setting in the settings menu of the left screen. I believe it is under the Display sub menu. Edit: check this video at 11:32: https://youtu.be/th9tmsntRSw&t=11m32s Edited April 9, 2024 by omar302 1 Quote Link to comment Share on other sites More sharing options...
bhamraS97 Posted April 9, 2024 Author Report Share Posted April 9, 2024 I am an idiot! Now I remember changing it when I got the car. Feels like I forgot my car completely 😆 Thank you! Quote Link to comment Share on other sites More sharing options...
