Yusuf Posted April 6, 2024 Report Share Posted April 6, 2024 I am a proud owner for Ford Edge St 2020 Performance 2.7 gasoline, since few days i am getting issue with my car, the steering got jammed and display some error messages which are : Service Advance Trac, Pre Collission Assist not available, Hill Assit Fault, it was happened once more before but after reset its gone but now again its showing the same and steering got jam can not be able to drive please Help me to resolve this issue. Errors Are Following ABS 5 Problems Error Codes U2107:68-68Collission Mitigation by Braking Continuous Memory DTCs C0051:67-68 Steering Wheel Position Sensor Continuous Memory DTCs C1109:64-68 Vehicle Dynamic Control Switch Continuous Memory DTCs U0429:86- AB Invalid Date Received From Steering Column Control Module U0420:00-AB Invalid Date Received From Power Steering Control Module AWD#1 : U0415:00-6C Invalid Date Received from ABS control Module IPM-A : U0418:86-AF Date Invalid From ABS Control Module PAM : U0415:00-2B Invalid Data Received From ABS Control Module SSCM : B10AD:08-0A Rain Sensor Continous Memory DTCs TRM : U2100:002F Initial Configuration Not Completed PSCM C200B:49-08 Steering Shaft Torque Sensor #1 C200B:62-08 Steering Shaft Torque Sensor #1 C200D:49-89 Motor Rotation Angle Sensor B1D23:4B-08 Overheat Sensor Quote Link to comment Share on other sites More sharing options...
garycrist Posted April 6, 2024 Report Share Posted April 6, 2024 How old is your ST's battery? Quote Link to comment Share on other sites More sharing options...
Yusuf Posted April 18, 2024 Author Report Share Posted April 18, 2024 On 4/6/2024 at 10:14 PM, garycrist said: How old is your ST's battery? almost new 2-3 months old Quote Link to comment Share on other sites More sharing options...
