Harleyflt04 Posted April 5, 2024 Report Share Posted April 5, 2024 i have a 2013 ford edge 3.5 no turbo pretty sure my pcm is bad .iam a mechanic and will do a pin out test iam trying to find the wiring dia pcm pin location and numbers as well as harness wiring pin and colors can someone please help me out thanks Quote Link to comment Share on other sites More sharing options...
Haz Posted April 5, 2024 Report Share Posted April 5, 2024 (edited) Welcome to the Forum @Harleyflt04! From the 2013 Edge Wiring Manual... Good luck! POWERTRAIN CONTROL MODULE (PCM) - Connector C175B Pin-Circuit Details - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Connectors C175B, C175E, C175T Location in Bulkhead - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Connector C175E Pin-Circuit Details - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Connector C175T Pin-Circuit Details - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #1 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #2 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #3 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #4 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #5 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #6 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #7 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #8 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #9 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #10 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #11 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Electronic Engine Controls #12 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Transmission Controls #1 - 3.5L TiVCT -2013 Edge.pdf POWERTRAIN CONTROL MODULE (PCM) - Transmission Controls #2 - 3.5L TiVCT -2013 Edge.pdf Edited April 5, 2024 by Haz 2 Quote Link to comment Share on other sites More sharing options...
garycrist Posted April 5, 2024 Report Share Posted April 5, 2024 Hey thanks @Haz, it was schematics like you provide that allowed me to find a power transistor that always failed on Cadillac DFI of the mid to late 70's! I fixed the computers for $2 transistor and resold them for $350 or $375 installed! 1 Quote Link to comment Share on other sites More sharing options...
