Dave886 Posted April 1, 2024 Report Share Posted April 1, 2024 I just found out from a friend that the 3rd brake light on my 2021 Edge ST blinks a few times continuously while I'm stopped and have the foot on the brake. After doing some research and taking it to the dealer (still under warranty) they told me that the previous owner have installed some aftermarket wiring to make it blink like that. I would've been fine if the light only blinks on hard braking while vehicle's moving, but having it blink while stopped is just overkill and must seem obnoxious to the drivers behind me. However, the dealer said they could remove the wiring and restore the factory state for $200. Obviously, I declined and would like to see if I can find the wiring mod myself so I can disable it. If anyone could share some idea of the aftermarket mod that may be causing this particular type of brake light behavior and where I should look to find and disable it, I'd greatly appreciate it. Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 1, 2024 Report Share Posted April 1, 2024 You could replace the flashing unit with a less offensive higher quality device. Search for YouTube videos for the installation of these flasher units and that will show you how to remove them and restore the wiring to original. This is what I use. https://www.amazon.com/dp/B0BN983DCS?psc=1&ref=ppx_yo2ov_dt_b_product_details Quote Link to comment Share on other sites More sharing options...
dabangsta Posted April 1, 2024 Report Share Posted April 1, 2024 A lot of dealers also add these on (not saying yours did, or the one the original owner bought it from did). I think this style is not legal because it doesn't change the intensity of the light (which needs to always be on), but turns it on and off (blinks) rapidly, then less rapidly, then on solid. I remove this from my Fusion: Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 1, 2024 Report Share Posted April 1, 2024 The one in the link I posted has a "Timeout lock" so that the 3rd brake light behaves as if it doesn't have the flasher module if in traffic where the brake is used repeatedly - mine are set to flash rapidly three times then solid, and will not flash again if the brake is applied for the next 30 seconds. Quote Link to comment Share on other sites More sharing options...
Dave886 Posted April 1, 2024 Author Report Share Posted April 1, 2024 Thanks for the responses. I was only able to find one video showing where the mod might be installed. Hopefully, I can just pry out the panel and find the spliced module in there. Quote Link to comment Share on other sites More sharing options...
