Yurez Posted March 27, 2024 Report Share Posted March 27, 2024 (edited) Does anyone have a wiring diagram for wireless charging? m1pt-19j235-aa Ford edge 2020 Edited March 27, 2024 by Yurez Quote Link to comment Share on other sites More sharing options...
Haz Posted March 27, 2024 Report Share Posted March 27, 2024 Wireless Accessory Charging Module (WACM) documents attached below... Wireless Accessory Charging Module (WACM) - Overview - 2020 Edge Workshop Manual.pdf Wireless Accessory Charging Module (WACM) - System Operation and Component Description - 2020 Edge Workshop Manual.pdf Wireless Accessory Charging Module (WACM) - Removal and Installation - 2020 Edge Workshop Manual.pdf Wireless Accessory Charging Module (WACM) - Diagnosis and Testing - 2020 Edge Workshop Manual.pdf Wireless Accessory Charging Module (WACM) - Grounds - Wiring Diagram - 2020 Edge.pdf Wireless Accessory Charging Module (WACM) - Power Distribution #1 - Wiring Diagram - 2020 Edge.pdf Wireless Accessory Charging Module (WACM) - Power Distribution #2 - Wiring Diagram - 2020 Edge.pdf Wireless Accessory Charging Module (WACM) - Module Communications #1 - Wiring Diagram - 2020 Edge.pdf Wireless Accessory Charging Module (WACM) - Module Communications #2 - Wiring Diagram - 2020 Edge.pdf Wireless Accessory Charging Module (WACM) - Wiring Diagram - 2020 Edge.pdf Wireless Accessory Charging Module (WACM) - Connector C390 Details - 2020 Edge.pdf Wireless Accessory Charging Module (WACM) - Connector C390 Location - 2020 Edge.pdf Good luck! 2 Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 27, 2024 Author Report Share Posted March 27, 2024 15 minutes ago, Haz said: Wireless Accessory Charging Module (WACM) documents attached below Thank you very much for your help. you are the best as always Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 28, 2024 Author Report Share Posted March 28, 2024 I can't connect the charger. I connected power to pin 1 and charge enable to pin 3. Ground at 5 pins. Charging doesn't work. Can it work without being connected to the car. Quote Link to comment Share on other sites More sharing options...
