Ctakacs9 Posted March 23, 2024 Report Share Posted March 23, 2024 Do the 2007 SELs have an IAC valve? Quote Link to comment Share on other sites More sharing options...
Haz Posted March 24, 2024 Report Share Posted March 24, 2024 From the 2007 Edge Workshop Manual... 3.5L Engine - Fuel Charging and Controls - Description and Operation Sequential Multi-Port Fuel Injection (SFI) The fuel charging and controls system consists of the: Throttle Body (TB) . fuel injectors. fuel rail. The fuel charging and controls system is: a Sequential Multi-Port Fuel Injection (SFI) system. Pulse Width Modulated (PWM) . Mass Air Flow (MAF) controlled. Fuel is metered into each intake port in a sequential firing order. Fuel injectors pulse to follow engine firing order, in accordance with engine demand, on a tuned intake manifold. The basic fuel requirement of the engine is determined from the data supplied to the PCM by the MAF sensor, which measures the amount of air being drawn into the engine. The various sensors detect any changes in the operating conditions and send signals to the PCM. This permits the PCM to control the opening duration (pulse width) of the fuel injectors and maintain optimum exhaust emission control and engine performance for all operating conditions. Throttle Body (TB) The TB : controls air supply to the intake manifold by electronically positioning the throttle plate. is not adjustable. Fuel Injectors The fuel injectors: are electronically operated by the PCM. atomize the fuel as the fuel is delivered. each have an internal solenoid that opens a needle valve, which injects fuel into the intake port in the cylinder head. are deposit resistant. Fuel Rail The fuel rail: receives fuel from the fuel supply tube. delivers fuel to the fuel injectors. The is no mention of an Idle Air Control (IAC) valve in the 2007 Edge Workshop Manual. There is no depiction of an IAC valve in the 2007 Edge Wiring Diagrams. There are no IAC-associated Diagnostic Trouble Codes (DTCs) included in the 2007 Edge Master DTC Chart. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Ctakacs9 Posted March 24, 2024 Author Report Share Posted March 24, 2024 (edited) 8 hours ago, Haz said: From the 2007 Edge Workshop Manual... Good luck! Thanks! Edited March 24, 2024 by 1004ron Quote Link to comment Share on other sites More sharing options...
