NC85 Posted March 22, 2024 Report Share Posted March 22, 2024 AC compressor is too close to the frame rail to get to the one bolt above the crank. I need to move the engine towards the firewall a couple inches to clear. I've followed the instructions from the workshop manual to a "T" but i'm stumped. I've seen people do it with the compressor installed, so I know it's possible. I just need to know a tip to move the engine a few inches towards the firewall to clear it. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
NC85 Posted March 22, 2024 Author Report Share Posted March 22, 2024 I just looked over my steps and I know what did or rather skipped. Skipped over the block heater notes and also mistakenly forgot to loosen the ROLL RESTRICTOR BOLTS...... Back on track, sort of......got to cut an exhaust stud and hopefully it ends at one. Then I should be on easy street to get the engine lowered and install the water pump, chains, etc. Got to love "old" stuff. Quote Link to comment Share on other sites More sharing options...
NC85 Posted April 15, 2024 Author Report Share Posted April 15, 2024 Final correct answer, remove the passenger side axle and disconnect the intermediate shaft from the bracket. Engine will lower and allow access to the bolt above the harmonic balancer. I don't think anyone works on this forum. Quote Link to comment Share on other sites More sharing options...
jmaurath Posted September 18, 2024 Report Share Posted September 18, 2024 can you share where you got your workshop manual? I'm getting ready to do the same job. Quote Link to comment Share on other sites More sharing options...
Haz Posted September 18, 2024 Report Share Posted September 18, 2024 Welcome to the Forum @jmaurath! Per your request, relevant Workshop Manual sections are attached below as PDF documents... Good luck! Air Conditioning (AC) Compressor — 3.5L, 3.7L - Removal and Installation - 2013 Edge Workshop Manual.pdfFetching info... Air Conditioning (AC) System Flushing - General Procedures - 2013 Edge Workshop Manual.pdfFetching info... Desiccant Bag - Removal and Installation - 2013 Edge Workshop Manual.pdfFetching info... Condenser Core — 3.5L, 3.7L - Removal and Installation - 2013 Edge Workshop Manual.pdfFetching info... Refrigerant Oil Adding - General Procedures - 2013 Edge Workshop Manual.pdfFetching info... Air Conditioning (AC) System Recovery, Evacuation and Charging - General Procedures - 2013 Edge Workshop Manual.pdfFetching info... Refrigerant Identification Testing - General Procedures - 2013 Edge Workshop Manual.pdfFetching info... Fluorescent Dye Leak Detection - General Procedures - 2013 Edge Workshop Manual.pdfFetching info... Radiator — 3.5L, 3.7L - Removal and Installation - 2013 Edge Workshop Manual.pdfFetching info... Thermostatic Expansion Valve — 3.5L, 3.7L - Removal and Installation - 2013 Edge Workshop Manual.pdfFetching info... Fender Splash Shield - Removal and Installation - 2013 Edge Workshop Manual.pdfFetching info... 2013 Edge AC Compressor Mounting - Enhanced Illustration - Exploded View with screws.pdfFetching info... 2013 Edge AC Compressor Mounting - Enhanced Illustration - Screw Tightening Sequence.pdfFetching info... Quote Link to comment Share on other sites More sharing options...
