jer2011 Posted March 21, 2024 Report Share Posted March 21, 2024 Hi. I have a 2015 Edge Titanium. I have a "Liftgate Ajar" indication, and the liftgate won't open. I have replaced the lock mechanism, then the liftgate control module. I now need to program the liftgate control module with the vin specific data. I am using forscan. Does anyone know how to program the module, or is it a dealer only problem? 1 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted March 24, 2024 Report Share Posted March 24, 2024 On 3/21/2024 at 1:39 PM, jer2011 said: Hi. I have a 2015 Edge Titanium. I have a "Liftgate Ajar" indication, and the liftgate won't open. I have replaced the lock mechanism, then the liftgate control module. I now need to program the liftgate control module with the vin specific data. I am using forscan. Does anyone know how to program the module, or is it a dealer only problem? supposedly there was a version of forscan that had module programming ability. I'd recommend searching the forums on the forscan site for a better answer. Quote Link to comment Share on other sites More sharing options...
Haz Posted March 25, 2024 Report Share Posted March 25, 2024 Welcome to the Forum, @jer2011! From the 2015 Edge Workshop Manual... If you installed a new module without saving its configuration data for transfer to the new module, you can obtain your Edge's As-Built all-module configuration record from the Ford Service Info site (link to opening page). Select your country and language from the drop-down lists and click the Submit button... Enter your Edge's VIN and the Security Check characters in their respective fields and click the Submit button... Your Edge's VIN-specific module configuration dataset will then be presented in hardcopy-printable text format (which your browser might also print to a PDF file), and the As-Built dataset can be downloaded as an .AB-format data file by clicking on the Download File button... The following chart includes 2015 Edge modules and their As-Built line-data addresses... (Placing your device cursor over underlined acronyms may yield their full-words description) Module Configuration and Parameter Chart Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Remote start enable/disable Perimeter alarm Tire pressure CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No None DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCDIM 7A5 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None GPSM 701 Yes Yes No None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Daytime running lamps control function Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SCCM 724 Yes Yes No None TRM 791 Yes Yes No None Manually entering As-Built data values and saving them to the target module will require Forscan equipped with at least a free 2-month Extended License. Just in case it's your Edge's Rear Gate Trunk Module (RGTM) that you replaced, the following are download links to relevant Workshop Manual sections... Body Closure - System Operation and Component Description - 2015 Edge Workshop Manual.pdf Module Configuration - System Operation and Component Description- 2015 Edge Workshop Manual.pdf Power Liftgate Initialization - General Procedures - 2015 Edge Workshop Manual.pdf Rear Gate Trunk Module (RGTM) Fuse F10 - 2015 Edge Wiring Diagram.pdf Body Control Module - Fuse Location Illustration - 2015 Edge Wiring Diagram.pdf Body Control Module - Fuse-to-Circuit(s) Legend - 2015 Edge Wiring Diagram.pdf Rear Gate Trunk Module (RGTM) - Removal and Installation - 2015 Edge Workshop Manual.pdf Good luck! 2 Quote Link to comment Share on other sites More sharing options...
jer2011 Posted March 25, 2024 Author Report Share Posted March 25, 2024 Thank you! Quote Link to comment Share on other sites More sharing options...
omar302 Posted March 25, 2024 Report Share Posted March 25, 2024 18 hours ago, Haz said: The following chart includes 2015 Edge modules and their As-Built line-data addresses... Do you have any additional information on the BCM Ambient lighting calibration? I don't recall reading this before. Quote Link to comment Share on other sites More sharing options...
Haz Posted March 26, 2024 Report Share Posted March 26, 2024 (edited) According to the Cyanlabs As-Built Database, Ambient Lighting configurations in the Body Control Module (BCM) are... Ambient Light Sensor Present Configuration Ambient Light Sensor Type Configuration Ambient Lighting Configuration Ambient Delay Configuration Additionally, their database shows Ambient Lighting-related configurations in the APIM/SYNC Module of... Ambient Light (AL) Ambient Light Type (ALT) The below-attached 2016 Edge Workshop Manual section provides useful Ambient Lighting info, however, the Cyanlabs database presents As-Built values in granular detail. Interior Lighting - System Operation and Component Description - 2016 Edge Workshop Manual.pdf Good luck! Edited March 26, 2024 by Haz 1 Quote Link to comment Share on other sites More sharing options...
