Trying to find replacement Part number
Hello,
Had a headlight bracket mounting point break.  I have attached a picture.  This is where the headlight would bolt down on the passenger side closest to the grill on a 2016 edge.  I am not having any luck finding the part.  What I really only need it the nut the bolt goes into as that appears to have separated and rotates freely so the headlight is loose but the whole plastic assembly would be fine as well.  Went to the ford dealership parts department with this but no luck they said they couldn't find the part anywhere in the system.
Ford parts is a good place to start. I was converting my rear license plate to four screws and after a few search queries found the "rear license plate bolt." I've also ordered rubber door bumpers and a front Ford name badge for decorative purposes from the site.
Edited by Tim W. AZ
