Raven9908 Posted March 19, 2024 Report Share Posted March 19, 2024 Hello, Had a headlight bracket mounting point break. I have attached a picture. This is where the headlight would bolt down on the passenger side closest to the grill on a 2016 edge. I am not having any luck finding the part. What I really only need it the nut the bolt goes into as that appears to have separated and rotates freely so the headlight is loose but the whole plastic assembly would be fine as well. Went to the ford dealership parts department with this but no luck they said they couldn't find the part anywhere in the system. Quote Link to comment Share on other sites More sharing options...
Tim W. AZ Posted March 21, 2024 Report Share Posted March 21, 2024 (edited) Ford parts is a good place to start. I was converting my rear license plate to four screws and after a few search queries found the "rear license plate bolt." I've also ordered rubber door bumpers and a front Ford name badge for decorative purposes from the site. Edited March 21, 2024 by Tim W. AZ Quote Link to comment Share on other sites More sharing options...
Haz Posted March 21, 2024 Report Share Posted March 21, 2024 (edited) Link to this FordParts webpage Radiator Support Assembly - Removal and Installation - 2016 Edge Workshop Manual.pdf Headlamp Assembly - Removal and Installation - 2016 Edge Workshop Manual.pdf Hood Latch - Removal and Installation - 2016 Edge Workshop Manual.pdf Active Grille Shutter - Removal and Installation - 2016 Edge Workshop Manual.pdf Front Bumper Cover - Removal and Installation - 2016 Edge Workshop Manual.pdf Cooling Module - 2.0L EcoBoost - Removal and Installation - 2016 Edge Workshop Manual.pdf Good luck! Edited March 21, 2024 by Haz 1 Quote Link to comment Share on other sites More sharing options...
