Yurez Posted March 6, 2024 Report Share Posted March 6, 2024 Good afternoon. The 2018 Ford EDGE 2.0 has replaced the single-screen instrument panel with the dual-screen instrument panel of the 2020 Titanium model with a power rear trunk lid. I don’t have one and an error appeared in the IPS for loss of communication with the rear door unit. Tell me how to correct the instrument panel configuration using Forscan. Quote Link to comment Share on other sites More sharing options...
Haz Posted March 9, 2024 Report Share Posted March 9, 2024 According to the CyanLabs Ford/Lincoln As-Built Module Configuration Database, you'll need to use Forscan to modify the Instrument Panel Control Module (IPC) Line 720-02-02 to Power Liftgate Control (PLC) Disabled and Power Liftgate Chime (LC) Non-DNA. Those two desired programming states are established in concert with programming for Passive Entry Passive Start (PEPS) and ParkAid Switch (PS), with the four potential Power Liftgate Control (PLC) Disable and Power Liftgate Chime (LC) Non-DNA combination-value lines highlighted in the following table... As-Built Programming Location 720-02-02: x⭐xx-xxxx ⭐Values 0=PEPS Disabled, PLC Disabled, PS Disabled, LC Non-DNA 1=PEPS Disabled, PLC Disabled, PS Disabled, LC DNA 2=PEPS Disabled, PLC Disabled, PS Enabled, LC Non-DNA 3=PEPS Disabled, PLC Disabled, PS Disabled, LC DNA 4=PEPS Disabled, PLC Enabled, PS Disabled, LC Non-DNA 5=PEPS Disabled, PLC Enabled, PS Disabled, LC DNA 6=PEPS Disabled, PLC Enabled, PS Enabled, LC Non-DNA 7=PEPS Disabled, PLC Enabled, PS Enabled, LC DNA 8=PEPS Enabled, PLC Disabled, PS Disabled, LC Non-DNA 9=PEPS Enabled, PLC Disabled, PS Disabled, LC DNA A=PEPS Enabled, PLC Disabled, PS Enabled, LC Non-DNA B=PEPS Enabled, PLC Disabled, PS Disabled, LC DNA C=PEPS Enabled, PLC Enabled, PS Disabled, LC Non-DNA D=PEPS Enabled, PLC Disabled, PS Disabled, LC DNA E=PEPS Enabled, PLC Enabled, PS Enabled, LC Non-DNA F=PEPS Enabled, PLC Enabled, PS Enabled, LC DNA As a real-world survey of these data points, I pulled As-Built files for a 2020 Edge SEL without Power Liftgate, and for a 2020 Edge Titanium with Power Liftgate, which as expected, are not identical in the above-described data position... Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 11, 2024 Author Report Share Posted March 11, 2024 Many thanks for the help. Here is my configuration. I still have the problem of displaying the opening of the trunk door on the dashboard and loss of communication with the parking assistance unit. Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 11, 2024 Author Report Share Posted March 11, 2024 Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 12, 2024 Author Report Share Posted March 12, 2024 (edited) In order to disable the error about loss of communication with the parking assistance module, you need to set 0 in cell 720-01-01 ХХХХ-ХХХХ-Х0ХХХ. The slob still has one error, U0103, loss of connection with the GSM module. Help me figure out if the shifter type is set incorrectly? Edited March 12, 2024 by Yurez 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted March 12, 2024 Report Share Posted March 12, 2024 (edited) Shift By Wire (SBW) Side Detect (SD) Sidemarker/Position Lamp Telltale (SPLT) Speedometer Cal (SC) Location 720-03-01: *xxx-xxxx-xxxx Values 0=SBW Disabled, SD Disabled, SPLT Disabled, SC North America 1=SBW Disabled, SD Disabled, SPLT Disabled, SC ECC (Europe) 2=SBW Disabled, SD Disabled, SPLT Enabled, SC North America 3=SBW Disabled, SD Disabled, SPLT Enabled, SC ECC (Europe) 4=SBW Disabled, SD Enabled, SPLT Disabled, SC North America 5=SBW Disabled, SD Enabled, SPLT Disabled, SC ECC (Europe) 6=SBW Disabled, SD Enabled, SPLT Enabled, SC North America 7=SBW Disabled, SD Enabled, SPLT Enabled, SC ECC (Europe) 8=SBW Enabled, SD Disabled, SPLT Disabled, SC North America 9=SBW Enabled, SD Disabled, SPLT Disabled, SC ECC (Europe) A=SBW Enabled, SD Disabled, SPLT Enabled, SC North America B=SBW Enabled, SD Disabled, SPLT Enabled, SC ECC (Europe) C=SBW Enabled, SD Enabled, SPLT Disabled, SC North America D=SBW Enabled, SD Enabled, SPLT Disabled, SC ECC (Europe) E=SBW Enabled, SD Enabled, SPLT Enabled, SC North America F=SBW Enabled, SD Enabled, SPLT Enabled, SC ECC (Europe) Notes Side Detect=BLIS Edited March 12, 2024 by Haz Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 12, 2024 Author Report Share Posted March 12, 2024 2 hours ago, Haz said: Shift By Wire (SBW) Side Detect (SD) Sidemarker/Position Lamp Telltale (SPLT) Speedometer Cal (SC) Location 720-03-01: *xxx-xxxx-xxxx Values 0=SBW Disabled, SD Disabled, SPLT Disabled, SC North America 1=SBW Disabled, SD Disabled, SPLT Disabled, SC ECC (Europe) 2=SBW Disabled, SD Disabled, SPLT Enabled, SC North America 3=SBW Disabled, SD Disabled, SPLT Enabled, SC ECC (Europe) 4=SBW Disabled, SD Enabled, SPLT Disabled, SC North America 5=SBW Disabled, SD Enabled, SPLT Disabled, SC ECC (Europe) 6=SBW Disabled, SD Enabled, SPLT Enabled, SC North America 7=SBW Disabled, SD Enabled, SPLT Enabled, SC ECC (Europe) 8=SBW Enabled, SD Disabled, SPLT Disabled, SC North America 9=SBW Enabled, SD Disabled, SPLT Disabled, SC ECC (Europe) A=SBW Enabled, SD Disabled, SPLT Enabled, SC North America B=SBW Enabled, SD Disabled, SPLT Enabled, SC ECC (Europe) C=SBW Enabled, SD Enabled, SPLT Disabled, SC North America D=SBW Enabled, SD Enabled, SPLT Disabled, SC ECC (Europe) E=SBW Enabled, SD Enabled, SPLT Enabled, SC North America F=SBW Enabled, SD Enabled, SPLT Enabled, SC ECC (Europe) Notes Side Detect=BLIS what value should be set and how is it related to blis? Quote Link to comment Share on other sites More sharing options...
Haz Posted March 13, 2024 Report Share Posted March 13, 2024 6 hours ago, Yurez said: Help me figure out if the shifter type is set incorrectly? 720-03-01: ⭐xxx-xxxx-xxxx I expect the U0103 DTC is the result of the 2020 IPC looking for its previous 2020 Edge's Shift By Wire (SBW) rotary shifter, but your 2018 Edge is not equipped with Shift By Wire (SBW), so the desired As-Built value ⭐ should include SBW Disabled. Per the IPC As-Built values you shared above, The present value of ⭐ is A, indicating SBW Enabled. A=SBW Enabled, SD Disabled, SPLT Enabled, SC North America To achieve SBW Disabled while maintaining the other three attributes in the combination. try... 4=SBW Disabled, SD Enabled, SPLT Disabled, SC North America With ⭐=4, hopefully, the U0103 DTC will not reoccur after you clear it from the Gear Shift Module (GSM). Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 13, 2024 Author Report Share Posted March 13, 2024 Maybe someone will find the final configuration of the dual-screen dashboard for the 2018 EDGE SE useful. Later, BLIS radars and heated mirrors will be installed. Thank you very much Haz for your help! 1 Quote Link to comment Share on other sites More sharing options...
Yurez Posted March 13, 2024 Author Report Share Posted March 13, 2024 There remains a small inaccuracy. The opening of the rear door is not displayed on the display; there is something else that can be corrected in the configuration? Quote Link to comment Share on other sites More sharing options...
