431 Steve Posted March 5, 2024 Report Share Posted March 5, 2024 Wife's car started squeaking from left front wheel, over bumps and when steering. Front suspension seems nice and tight, lubed the control arm bushings, upper strut mounts, and the links between the upper and lower control arms. The noise went away for about 100km, now it's back with a vengeance. I fear it's the rack and pinion assembly... It has 125000 well maintained kilometers on it, what else might be to blame? Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted March 5, 2024 Report Share Posted March 5, 2024 (edited) Might take a look at the sway bar links and also the strut mounts. Disregard, didn't realize you mentioned this already. Must've been half asleep. Edited March 6, 2024 by kruzr1 Quote Link to comment Share on other sites More sharing options...
431 Steve Posted June 2, 2024 Author Report Share Posted June 2, 2024 So, I went ahead and replaced the swaybar end links, and because I'm a glutton for punishment, I did the swaybar mount bushings as well... Things I learned today: 1. the bushings were definitely the culprit. 2. That is NOT a job to be done with a jack and a couple of jack-stands. The left side was a pain in the a**. The right side took almost 2 hours to do. I think a Ford shop would probably pull the motor to do those, there's only about 3/8" clearance between the bracket and the steering rack. Wouldn't recommend Quote Link to comment Share on other sites More sharing options...
