10sne1 Posted February 26, 2024 Report Share Posted February 26, 2024 Boat trailer lights turn them selves on? The boat is hooked up and lights are plugged in. I lock the doors, lights blink, all lights go off. 15 minutes later we see the lights on the trailer are on? No lights are on inside or out side my 2020 Edge? Same thing happened at the ramp, when I returned from fishing trailer lights on, nothing on the car? Now I am unplugging the trailer lights, when not towing. Crazy, any thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
dabangsta Posted February 27, 2024 Report Share Posted February 27, 2024 Are they LED lights? Is it the factory towing or added on hitch and wiring? Are the lights at full intensity when the car is off, or are the very dim? I have had this issue with LED things and current bleed, where the controller has a tiny bit of current to sense and that is enough to dimly light LEDs. At night they look brighter than you would think, during the day sometimes not even able to tell. Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 27, 2024 Report Share Posted February 27, 2024 A similar discussion came up earlier. Check this post. 1 Quote Link to comment Share on other sites More sharing options...
dajo2012 Posted February 27, 2024 Report Share Posted February 27, 2024 There is a computer upgrade that will fix this. My 20ST also did this until dealer did update. Ford issued a bulletin or some service info on this. Quote Link to comment Share on other sites More sharing options...
