trans. serching
1BadSanta
MIles on your transmission?
Is the ATF level where it should be, check with Transmission warmed up & engine idling is park on level ground?
Has the Trans ATF ever been drained & renewed; recommend every 33kMiles\4years?
Can try an additive like LucasTransmissionFix
or drain+refill with a premium MerconV compatible ATF like AmsOil#HighTempATF.
Edited by DILLARD000
