trelli86 Posted February 19, 2009 Report Share Posted February 19, 2009 The Death Magnetic album will not play on the jukebox via voice command! This is the only album I have a problem with. Now, if I use my iPod, there is no problem. It recognizes the command and plays without hesitation. Quote Link to comment Share on other sites More sharing options...
CreamEDGE. Posted February 20, 2009 Report Share Posted February 20, 2009 Because of the excessive range compression and clipping?? haha. Quote Link to comment Share on other sites More sharing options...
Kanatronic Posted February 22, 2009 Report Share Posted February 22, 2009 Because of the excessive range compression and clipping?? haha. That is a joke probably, but trust me that Death Magnetic is not one of the worst cases of those problems, indeed the prior album was far worst...Death Magnetic to me, sounded very good in comparison to what is made nowdays in the recording industry...But anyway if this were the case, what the compression and clipping has to do with the voice commands for paying it??? I'm assuming that something was done wrong while ripping/copying it... Quote Link to comment Share on other sites More sharing options...
MustangMike Posted February 22, 2009 Report Share Posted February 22, 2009 Thats funny, mine plays I.C.P. just fine...... Quote Link to comment Share on other sites More sharing options...
CreamEDGE. Posted February 22, 2009 Report Share Posted February 22, 2009 (edited) That is a joke probably, but trust me that Death Magnetic is not one of the worst cases of those problems, indeed the prior album was far worst...Death Magnetic to me, sounded very good in comparison to what is made nowdays in the recording industry...But anyway if this were the case, what the compression and clipping has to do with the voice commands for paying it??? I'm assuming that something was done wrong while ripping/copying it... It's pretty bad, Britney Spears' album Circus doesn't even have that much range compression and clipping. The GH3 rip sounds much better than the commercial release. But what I said was mostly a joke, has nothing to do with SYNC. It might be the ID3 tag. Edited February 22, 2009 by CreamEDGE. Quote Link to comment Share on other sites More sharing options...
Kanatronic Posted February 23, 2009 Report Share Posted February 23, 2009 (edited) It's pretty bad, Britney Spears' album Circus doesn't even have that much range compression and clipping. The GH3 rip sounds much better than the commercial release. But what I said was mostly a joke, has nothing to do with SYNC. It might be the ID3 tag. Comparing a Metallica song with BS (Britney Spears by coincidence has the same initials) is like comparing apples to oranges, the music is not even similar, and the way it was played distorted, effected, recorded, neither, if you take a quiet passage of any Metallica song for example, and compare it ot any BS song you will see they are not that far, now you take a congested passage as they one you are probably using there, and comparing it with BS, will give you that same result... Anyway I'm not saying that is perfect, I'm saying that is better than the prior one, that was indeed horrible... Edited February 23, 2009 by Kanatronic Quote Link to comment Share on other sites More sharing options...
