Deecee50 Posted February 13, 2024 Report Share Posted February 13, 2024 I replace the rear subframe and now it sits high..I left everything loose for it to settle but no luck. Should I take it for a ride to see if it will settle down? Thanxs (puzzled) Quote Link to comment Share on other sites More sharing options...
handfiler Posted February 14, 2024 Report Share Posted February 14, 2024 Well if you haven't driven it yet that could be the problem. Anytime you lift a vehicle to work on it, it wit sit higher until you drive it. The suspension won't settle until you drive it. Quote Link to comment Share on other sites More sharing options...
