Reid Posted February 8, 2024 Report Share Posted February 8, 2024 (edited) Hi, When I pull the lever for bright lights, nothing happens. No sound, no dash light, no change in the head lights. The lever feels normal, it has a click when I pull it back, it just doesn't register. This is a different headlight setup than I am used to, I don't know where to start trouble shooting. I did check all the fuses under the dash, all good. Any ideas where to look first? Edited February 8, 2024 by Reid More info Quote Link to comment Share on other sites More sharing options...
fishx65 Posted February 8, 2024 Report Share Posted February 8, 2024 (edited) Don't expect any more light when using the brights, there's just a shutter that moves which allows the light to go higher. The halogen projectors on 11-14 Edges are so bad they're borderline dangerous. Edited February 9, 2024 by fishx65 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted February 8, 2024 Report Share Posted February 8, 2024 (edited) I think that 2011-2012 that it was pull, not push. You pull it back far enough for it to "click" for high beams, or only slightly for "flash to pass". Weird that it isn't the normal, and not what previous or since Edge's or most Fords work. If you have a wall on front of you, this is low beam (note the cut off line, I also have the fog lights on...and this is a different vehicle but has halogen projectors and not bi-halogen that is why the cut off remains for the high beams): and high beams have a much bigger hot spot: Edited February 8, 2024 by dabangsta 1 Quote Link to comment Share on other sites More sharing options...
Reid Posted February 10, 2024 Author Report Share Posted February 10, 2024 Yep, it only pulls. I can see the cut off line on my lights. I think I will try to test the shutters. If they are good, I will try a new switch on the steering column. Quote Link to comment Share on other sites More sharing options...
