2FMDK3KC5DBA79### Posted February 2, 2024 Report Share Posted February 2, 2024 Does anyone have the Ford Troubleshooting procedure for the sunroof on a 2013 Ford Edge Limited? I performed the reset procedure several times and it worked once but messed up by opening the sunroof again to test it and it won’t close completely and will not reset now. I’ve cleaned the tracks with a nylon brush and lubed them with white lithium grease. Quote Link to comment Share on other sites More sharing options...
Haz Posted February 4, 2024 Report Share Posted February 4, 2024 (edited) Welcome to the Forum, 2FMDK3KC5DBA79### ! From the 2013 Edge Workshop Manual... Pinpoint Test E: The Roof Opening Panel Does Not Open or Close — Sliding Glass Panel or Shades Inoperative The roof opening panel motors must be initialized whenever any of the following occur: the roof opening sliding glass panel motor has been removed. a new roof opening sliding glass panel motor has been installed. a new roof opening panel module assembly has been installed. Refer to Roof Opening Panel Motor Initialization attached .below. Refer to Roof Opening Panel Wiring Diagrams for schematic and connector information, attached .below. Normal Operation The roof opening panel uses an integrated motor and module to operate the roof opening sliding glass panel and shades. NOTE: The roof opening panel control switch operates both the power shade and the sliding glass panel. The sliding glass panel opens after the shade panels are open. The shade panels close only after the sliding glass panel is closed. NOTE: Any sliding glass opening operation first fully opens the shade panels. Before closing the shade panels, fully close or make sure the sliding glass panel is fully closed. The roof opening sliding glass panel motor receives voltage from the accessory delay relay when the ignition is in the ACC or RUN position. The roof opening sliding glass panel motor and roof opening panel shade motor also receive voltage at all times through another power circuit. Ground is supplied to the roof opening sliding glass panel motor, roof opening panel shade motor and roof opening panel switch. The roof opening panel switch supplies ground signal(s) to the sliding glass panel motor for opening and closing operations. When commanding the glass to open, the sliding glass motor either requests the shade motor to fully open the shades (if they are not already in the fully OPEN position) or the roof opening panel sliding glass moves to the OPEN position. When commanding the glass to close, the sliding glass motor closes the sliding glass panel to the safety stop position (approximately 280 mm (11.023 in) from the fully CLOSED position). Pull and hold the roof opening panel switch until the sliding glass panel has completely closed before pulling the switch again to close the shades. For information about the roof opening sliding glass panel and shade operation, refer to Roof Opening Panel attached below. The roof opening sliding glass panel motor acts as a master controller to the shade motor. The sliding glass panel motor and shade motor communicate to each other through a dedicated circuit within the roof opening panel jumper harness. The sliding glass panel motor and shade motor do not communicate to the vehicle network. This pinpoint test is intended to diagnose the following: Fuse(s) Accessory delay relay Roof opening sliding glass panel motor not initialized Roof opening panel shade motor not initialized Wiring, terminals or connectors Roof opening panel switch Roof opening panel shade motor Roof opening sliding glass panel motor PINPOINT TEST E : THE ROOF OPENING PANEL DOES NOT OPEN OR CLOSE — SLIDING GLASS PANEL OR SHADES INOPERATIVE NOTE: Use the correct probe adapter(s) from the Flex Probe Kit when making measurements. Failure to use the correct probe adapter(s) may damage the connector. E1 CHECK THE POWER WINDOWS Ignition ON. Attempt to operate the power windows. Do the power windows operate? Yes GO to E2. No REFER to Section 501-11 to diagnose the inoperative power windows (accessory delay relay circuit). E2 CHECK THE ROOF OPENING PANEL MOTOR FOR INITIALIZATION Attempt to carry out the roof opening panel motor initialization procedure. Refer to Roof Opening Panel Motor Initialization attached below. Is the concern still present, or does the roof opening panel motor fail to initialize? Yes GO to E3. No The system is operating normally at this time. The roof opening panel motor was not initialized. E3 CHECK THE ROOF OPENING PANEL SWITCH Ignition OFF. Disconnect: Roof Opening Panel Switch C9001 . Carry out the roof opening panel switch component test, attached below. Did the roof opening panel switch pass the component test? Yes GO to E4. No INSTALL a new roof opening panel switch. REFER to Roof Opening Panel Control Switch attached below. TEST the system for normal operation. E4 CHECK VOLTAGE TO THE ROOF OPENING PANEL MOTOR ASSEMBLY Disconnect: Roof Opening Panel Motor Assembly C920 . Ignition ON. Measure the voltage between roof opening panel motor assembly C920 Pin 13, circuit CBP32 (GN/VT), harness side and ground; and between C920 Pin 1, circuit SBB08 (VT/RD), harness side and ground. Are the voltages greater than 10 volts? Yes GO to E5. No VERIFY Body Control Module (BCM) fuse 32 (15A) and Battery Junction Box (BJB) fuse 8 (20A) are OK. If OK, REPAIR the circuit. TEST the system for normal operation. If not OK, REFER to the Wiring Diagrams manual to identify the possible causes of the circuit short. REPAIR the circuit. TEST the system for normal operation. E5 CHECK THE ROOF OPENING PANEL MOTOR ASSEMBLY GROUND Ignition OFF. Measure the resistance between roof opening panel motor assembly C920 Pin 8, circuit GD133 (BK), harness side and ground. Is the resistance less than 5 ohms? Yes GO to E6. No REPAIR the circuit. TEST the system for normal operation. E6 CHECK THE ROOF OPENING PANEL SWITCH GROUND FOR AN OPEN CIRCUIT Connect: Roof Opening Panel Motor Assembly C920 . Measure the resistance between roof opening panel switch C9001 Pin 2, circuit CPR39 (VT/WH), harness side and ground. Is the resistance less than 5 ohms? Yes GO to E7. No REPAIR the circuit. TEST the system for normal operation. E7 CHECK THE ROOF OPENING PANEL SWITCH CIRCUITS FOR A SHORT TO GROUND Disconnect: Roof Opening Panel Motor Assembly C920 . Using the following table, measure the resistance between roof opening panel motor assembly C920, harness side and ground: Roof Opening Panel Motor Assembly Ground C920 Pin 2, circuit CPR31 (VT/BN) Ground C920 Pin 4, circuit CPR40 (YE/OG) Ground C920 Pin 6, circuit CPR38 (WH/BU) Ground Are the resistances greater than 10,000 ohms? Yes GO to E8. No REPAIR the circuit(s) in question. TEST the system for normal operation. E8 CHECK THE ROOF OPENING PANEL SWITCH CIRCUITS FOR AN OPEN Measure the resistance between roof opening panel switch C9001, harness side and roof opening panel motor assembly C920, harness side using the following table: Roof Opening Panel Switch Circuit Roof Opening Panel Motor Assembly C9001 Pin 3 CPR40 (YE/OG) C920 Pin 4 C9001 Pin 4 CPR31 (VT/BN) C920 Pin 2 C9001 Pin 6 CPR38 (WH/BU) C920 Pin 6 Are the resistances less than 5 ohms? Yes GO to E9. No REPAIR the circuit(s) in question. TEST the system for normal operation. E9 CHECK THE ROOF OPENING PANEL MOTOR WIRING HARNESS Using the following table, check the roof opening panel motor wiring harness for loose pins, an open or a short between roof opening panel motor assembly C920 component side and the roof opening panel sliding glass motor harness connector: Roof Opening Panel Motor Assembly Roof Opening Panel Sliding Glass Motor Harness Connector C920 Pin 1, circuit SBB08 Roof opening panel sliding glass motor harness connector circuit SBB08 C920 Pin 13, circuit CBP41 Roof opening panel sliding glass motor harness connector circuit CBP41 C920 Pin 8, circuit GD133 Roof opening panel sliding glass motor harness connector circuit GD133 C920 Pin 2, circuit CPR31 Roof opening panel sliding glass motor harness connector circuit CPR31 C920 Pin 6, circuit CPR38 Roof opening panel sliding glass motor harness connector circuit CPR38 C920 Pin 4, circuit CPR40 Roof opening panel sliding glass motor harness connector circuit CPR40 Is the roof opening panel motor wiring harness OK? Yes GO to E10. No INSTALL a new roof opening panel motor wiring harness. REFER to Roof Opening Panel Motor Wiring Harness attached below. INITIALIZE the roof opening panel motor. REFER to Roof Opening Panel Motor Initialization attached below. TEST the system for normal operation. E10 CHECK THE ROOF OPENING PANEL MOTOR ASSEMBLY FOR CORRECT OPERATION Disconnect all roof opening panel motor connectors (sliding glass motor and shade motor). Check for: corrosion. bent or pushed-out pins. Connect all roof opening panel motor connectors and make sure they seat correctly. Operate the system and verify the concern is still present. Is the concern still present? Yes INSTALL a new roof opening sliding glass panel motor. REFER to Roof Opening Panel Motor — Sliding Front Panel attached below. INITIALIZE the roof opening panel motor. REFER to Roof Opening Panel Motor Initialization in this section. TEST the system for normal operation. If the concern is still present, INSTALL a new roof opening panel shade motor. REFER to Roof Opening Panel Motor — Shade attached below. INITIALIZE the roof opening panel motor. REFER to Roof Opening Panel Motor Initialization attached below. TEST the system for normal operation. No The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation. Document download links> Roof Opening Panel - Description and Operation - 2013 Edge Workshop Manual.pdf Roof Opening Panel - Wiring Diagram 1 - 2013 Edge.pdf Roof Opening Panel - Wiring Diagram 2 - 2013 Edge.pdf Roof Opening Panel Motor Initialization - General Procedures - 2013 Edge Workshop Manual.pdf Console — Overhead - Removal and Installation - 2013 Edge Workshop Manual.pdf ROOF OPENING PANEL SWITCH - Component Testing Procedure - 2013 Edge.pdf ROOF OPENING PANEL SWITCH - Connector C9001 Details - 2013 Edge.pdf ROOF OPENING PANEL SWITCH - Connector C9001 Location - 2013 Edge.pdf ROOF OPENING PANEL MOTOR ASSEMBLY - Connector C920 Details - 2013 Edge.pdf ROOF OPENING PANEL MOTOR ASSEMBLY - Connector C920 Location - 2013 Edge.pdf Roof Opening Panel Motor Wiring Harness - Removal and Installation - 2013 Edge Workshop Manual.pdf Roof Opening Panel Motor — Sliding Front Panel - Removal and Installation - 2013 Edge Workshop Manual.pdf Roof Opening Panel Motor — Shade - Removal and Installation - 2013 Edge Workshop Manual.pdf Good luck! Edited February 4, 2024 by Haz 1 Quote Link to comment Share on other sites More sharing options...
