JPJMustang Posted January 25, 2024 Report Share Posted January 25, 2024 Started the 3.5 the other day - starting to have a loud noise (not normal low ticking) - sounds like a rocker/lifter noise. Sound when idling Will go away when you step on the break and put in gear. But can still hear (not as loud) Tried heavier oil - but still had the sound In your opinions - ok to drive (just annoyance) - or should I pull covers and try to replace lifters? - assume hydraulic lifters - Am I correct? JPJM Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted February 25, 2024 Report Share Posted February 25, 2024 (edited) Could try an oil additive (Lucas "engine honey"), or a premium brand of oil like AmsOil (extra additives for minimizing wear.). Have a personal habit of spraying a little Carb+ThrottleCleaner down the Oil DipTube & Oil Fill, then run engine idling for 5~10 minutes, then change Oil+Filter; believe this helps clear out sludge+dirt deposits throughout the engine. Of course do make sure your oil level is in the upper range on the DipStick.. Also put an eyeball on your 2 belts; a belt or belt tensioner can tick loudly if they're getting worn. Edited February 25, 2024 by DILLARD000 Quote Link to comment Share on other sites More sharing options...
