A feature on Sync 4 that would be nice on the Sync 3 on my Edge
Something that has always bugged me on my 2020 Edge with Sync 3 is that if I'm using Android Auto and I want to change something on the Ford Sync system, like the steering wheel heater for example, i have to tap the screen so many times to get to the heater button and back. Or if you want to talk to the Ford Sync, you have to back out of Android Auto.
I got a 2023 Ford Transit with Sync 4 and a large tablet style display and Sync 4 has a very good solution to this problem. When Android Auto is on the screen, there is a mic icon. If you tap that, you talk to google assistant. If you press the "speak" button on the steering wheel, you get Ford Sync so you can say "set temp to x degrees."
I'm just wondering if there's any way to change the behavior on Sync 3 to match the behavior on Sync 4.
