jjmaine Posted January 16 Report Share Posted January 16 This morning on my way to work, when I came out of the store and started my car it was apparent it had just developed an exhaust leak. I spent an hour after work climbing under the car trying to find it but there are no telltale spot marks or holes with moisture anywhere. From what I've read here my guess would be the flex pipe since those commonly fail? I just hope it isn't the manifold bolts because it looks like you would have to pull the engine to get to the rear manifold and that would be expensive. Does anyone know a way to check if the flex pipe is leaking under that mesh where you can't see it? I put my hand around it but could not feel any air leaking out??? Quote Link to comment Share on other sites More sharing options...
