DEEz Posted January 2, 2024 Report Share Posted January 2, 2024 (edited) I've been a member here a while & have had/have Escapes, Edges, Lincoln Mkx & now a mercury Mariner in the family which have similar systems. I recently bought a non running 2010 mercury Mariner with the 2.5L (non-ecoboost) & I've come across strange symptoms. No codes showing from my basic code scanner (the battery was dead & had been sitting up almost a year). I found 1 ignition key/fob (out of the 2 key/fobs i have) that would not activate the starter (i even replaced the fob batteries), the dash screen will show "No Mykeys programmed" & 2 Admin keys programmed). I'm NOT getting a fast flash of the theft light on the dash (did get the fast light with the bad key & likely was in use when the vehicle shut off with the previous owner). The engine will run (& stay running) on starting fluid but I'm not getting any rpm input from my foot on the throttle (throttle by wire). Without using starting fluid the engine will start & run for like 3 seconds, i can recycle the key a couple times until i hear the pump activate again & it will start/run 3 seconds again & again (seems like PATS is responsible but I'm not getting the fast dash light). I don't see a manual access port to check the fuel pressure. When I pull 1 of the 3 connectors off the computer & reinstall it i do hear the throttle body operate & possibly sweeping (resetting). I tried connecting forscan the other day with a "no connection" as the response but that was before I found i had 1 bad key fob so I plan to try it again. Oh, when I was checking the relays under the hood I noticed 1 of the radiator fans would operate constantly (wasn't sure if its a separate issue or a symptom of the main issue. Does anyone have any incite? Thanks . Edited January 3, 2024 by DEEz Quote Link to comment Share on other sites More sharing options...
DEEz Posted January 3, 2024 Author Report Share Posted January 3, 2024 "Unable to connect to vehicle" with forscan. No issues with it connecting to a 09 f150 & 2017 Edge in the yard. . Quote Link to comment Share on other sites More sharing options...
Haz Posted January 4, 2024 Report Share Posted January 4, 2024 No personal insights to offer in this case, just subject-vehicle information and topical diagnostic procedures from Ford's 2010 Gasoline Powertrain Control / Emissions Diagnosis (PC/ED) Manual in this and another immediately following post, due to Forum file attachment limitations... Document download links> Fuel Charging and Controls - 2.5L - 2010 Escape-Mariner Workshop Manual.pdf Fuel System Pressure Release - General Procedures - 2010 Escape-Mariner Workshop Manual.pdf Quick Connect Coupling - General Procedures - 2010 Escape-Mariner Workshop Manual.pdf Fuel System Pressure Test - General Procedures - 2010 Escape-Mariner Workshop Manual.pdf Throttle Body - Removal and Installation - 2.5L - 2010 Escape-Mariner Workshop Manual.pdf Throttle Body - R&I Enhanced Image - 2.5L - 2010 Escape-Mariner Workshop Manual.pdf Fuel Rail and Fuel Injector - Exploded View - 2.5L - 2010 Escape-Mariner Workshop Manual.pdf Fuel Rail and Fuel Injector - Exploded View Enhanced Image #1 - 2.5L - 2010 Escape-Mariner Workshop Manual.pdf Fuel Rail and Fuel Injector - Exploded View Enhanced Image #2 - 2.5L - 2010 Escape-Mariner Workshop Manual.pdf Fuel Rail - Removal and Installation - 2010 Escape-Mariner Workshop Manual.pdf Fuel Pump Control Module - Removal and Installation - 2.5L - 2010 Escape-Mariner Workshop Manual.pdf Quote Link to comment Share on other sites More sharing options...
Haz Posted January 4, 2024 Report Share Posted January 4, 2024 Additional... Document download links> Pinpoint Test DD - Fuel Rail Pressure (FRP) and Fuel Rail Pressure Temperature (FRPT) Sensors.pdf Pinpoint Test KC - Fuel Pump Control Module.pdf Good luck! Quote Link to comment Share on other sites More sharing options...
