AZ Shiflett Posted December 20, 2023 Report Share Posted December 20, 2023 Any suggestions which dashcam to buy and how/where to mount and power it? Quote Link to comment Share on other sites More sharing options...
FX3 Posted December 21, 2023 Report Share Posted December 21, 2023 I have Street Guardian in 3 of my cars. All are 2 channel. Not cheap, good quality and support is great. Front is below and slightly left of mirror mount. Rear is top center. I got the parking mode power connector so it gets power from an add-a-fuse in the fuse panel. All wires run to driver side and down A pillar to fuse box. Rear cabling run down driver side headliner. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 11, 2024 Report Share Posted May 11, 2024 (edited) On 12/20/2023 at 1:14 PM, AZ Shiflett said: Any suggestions which dashcam to buy and how/where to mount and power it? Everyone has their favorites, all depends on what you want in your finished installation. I'd recommend you start by reading this article from Car & Driver Magazine on dash cams, 2024. https://www.caranddriver.com/car-accessories/g46063800/best-dash-cams-tested/?utm_source=google&utm_medium=cpc&utm_campaign=arb_ga_cd_md_bm_comm_org_us_g46063800&gad_source=1&gclid=CjwKCAjwrvyxBhAbEiwAEg_KgjO2U3L-obq75WsecUnPMW88xk4Gn47lZvksEmgrY4C2V4v30UZnThoCCU0QAvD_BwE As for mounting, I've found that a mirror mount is superior to the suction cup mounts (they all fall, no matter how well their installed.) Example: https://rammount.com/collections/car-truck-ford-edge For wiring, I'd recommend using a quality wire harness plugged into your rear view mirror connector. Shortens installation to a couple of minutes and turns the camera off when the timed circuit turns off (or door opened.) For example: Dongar Dashcam Power Adapter (5-pin Type F) for Select Ford Vehicles. Compatible with Mach-E, Bronco Sport, Explorer and More. Built-in USB Power Source, Connects to Rearview Mirror, Easy to Install https://a.co/d/5aj6IQ3 Edited May 11, 2024 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
