oskar27 Posted December 9, 2023 Report Share Posted December 9, 2023 Kind of funny problem guys but its annoying. I have my 2016 Titanium FWD since new with zero problems. In Canada we change to winter tires every December and been doing this since new but this time after I finish (have to remove the trunk floor over the spare tire to get the jack etc.) there is a rattling noise on the back and close to the inside of the tail gate. No way I can find out why/where but I'm sure its the floor over the spare tire which is some kind of board covered with black thin carpet and feel it is loose. Does this board some how attaches to somewhere to keep it in place? Thanks Quote Link to comment Share on other sites More sharing options...
Haz Posted December 10, 2023 Report Share Posted December 10, 2023 Have you tried removing the panel(s) you describe and taking a test drive, in order to confirm or eliminate it as the source of the noise/vibration/harshness? From the 2016 Edge Workshop Manual... Remove the load compartment floor cover. If equipped: Remove the spare tire cover. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 10, 2023 Author Report Share Posted December 10, 2023 Yes It is the panel in your first picture which feels "loose" in my car. I remember when I used to lift that panel to access the storage spaces under it, after it used to kind of "fit or locked" somewhere / somehow. Now it sit loose and yesterday when driving I noticed the end of it by the rear gate was flopping up/dn and making the rattling sound Last night I play with it and now somehow "feels" its stuck somewhere. Will test drive it today or tomorrow and post back. If noise is still there I will test drive without that panel. Thanks for your time 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 10, 2023 Report Share Posted December 10, 2023 (edited) There are 2 tie down hooks (loops), make sure they are not under the loose panel, otherwise the panel will not fully seat. Also, the storage bins have raised nibs that go in to slots under the panel. So if they are not aligned correctly, the panel would also not seat correctly. Edited December 11, 2023 by omar302 Spelling 1 1 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 10, 2023 Author Report Share Posted December 10, 2023 Many thanks for the tips, I will check them out. Freezing rain here so test drive will take place perhaps tomorrow 1 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 12, 2023 Author Report Share Posted December 12, 2023 Well the annoying noise it becomes now a PITA. Test driving today it definitely comes from the drivers side and just behind the rear gate. So I stopped, lower the backs of the rear seats and pushed the trunk floor cover towards the rear seats. No the sound again is there. Next step is to empty the trunk including the spare wheel and give it a try. When I get a chance to do this work I will post back Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 15, 2023 Author Report Share Posted December 15, 2023 Empty the trunk completely including the spare tire and drove around and the rattling noise still there. Looked under the car and see nothing neither expecting to see anything cause the noise comes from the inside of the car and in particular on the driver side and just behind the inside of rear gate. Thats the side where the gas tank is. The rear gate closes tight so its not her making the noise. The rear gate at the bottom is about 3" to 4" thick, is it possible something inside the gate came loose? The license plate is not loose neither any of the rear lights. I just cant figure it out. Next try will be on the weekend and have wife sitting on the back seats and see if she can pin point something other wise I will have to go to the dealer but with X-Mas approaching most likely I will do it in January. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted December 17, 2023 Report Share Posted December 17, 2023 Just in case you wish to remove a trim panel to confirm your discovery... Document download links> Loadspace Trim Panel - Removal and Installation - 2016 Edge Workshop Manual.pdf Liftgate Trim Panel - Removal and Installation - 2016 Edge Workshop Manual.pdf Good luck! 2 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 17, 2023 Author Report Share Posted December 17, 2023 Much appreciate your time Haz and many thanks. I did remove the lift gate panel and found nothing wrong. Tomorrow I will take a drive with the wife at the back seat to see if we can pinpoint where the noise comes from. I dont expect any major discovery so my plan is on Monday to call the dealer for an appointment. Soon I have news I will post the results here 1 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 17, 2023 Author Report Share Posted December 17, 2023 More info in the attachment 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted December 17, 2023 Report Share Posted December 17, 2023 (edited) Click on this link to download the full Removal and Installation procedure... Loadspace Trim Panel - Removal and Installation - 2016 Edge Workshop Manual.pdf Good luck! Edited December 17, 2023 by Haz 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted December 17, 2023 Report Share Posted December 17, 2023 If your Edge is equipped with the Sony Audio System, the Sony Audio Digital Signal Processing (DSP) Module is mounted immediately behind the Loadspace Trim Panel that you have marked in your photo... Good luck! 2 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 17, 2023 Author Report Share Posted December 17, 2023 Thank again Haz, I do have the Sony and that makes me believe that module in banking inside the cavity. I will check it tonight or tomorrow and report back. 1 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted December 18, 2023 Author Report Share Posted December 18, 2023 Had a quick look tonight to remove the panel but I think it is a big job for me. Will have another look tomorrow and decide if going to the dealer is a better alternative. Quote Link to comment Share on other sites More sharing options...
oskar27 Posted January 16 Author Report Share Posted January 16 The problem persist and best alternative is the dealer but due to weather and bad traffic (have to cross a bridge which now is under repairs and chaos to cross) I always postpone to make an appointment. Trying to remove the big side panel by the loading area is impossible for me, pulling up and away from the wall it feels I will damage it. However I noticed when the rear seats are up the noise almost disappears or not as frequent so I now believe this noise is related to the rear seats recline mechanism. Reading on the web they say the 2 motors under the rear seats are connected to the switch on the drivers side rear panel via a "tunnel". I also noticed there is a steel cable per motor which goes towards that rear panel. If the "tunnel" is metallic then the noise I hear is that, a steel cable banging on the walls of metal. To view the motors mechanism properly under the rear seats I am able to lift the one pc seat but there are cables attached to it and before removing the seat I should first disconnect these cables. Is there any schematic available of all wiring / mechanism involved on the 2 reclining motors? (2016 Edge Titanium) Thanks Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted January 18 Report Share Posted January 18 I had a similar rattle shortly after installing winter tires this year, and thought it was something inside the cabin rattling. Turned out to be the upper shock mounts on the rear shocks - more specifically the bushings in the mounts were badly worn. Ours has about 88,000 Kms on it. It sounded like a seat belt or seat was loose when it first happened, and got progressively worse. The mounts can be replaced separately, but at 50,000+ miles it was probably time for new shocks anyway. Our shop replaced both side mounts and shocks (with a 'kit' of parts) in under an hour and the noise was gone. 1 Quote Link to comment Share on other sites More sharing options...
oskar27 Posted January 18 Author Report Share Posted January 18 Thanks for the help mate, something new to look for but I will be very surprised if its the shock mounts. As I mentioned I am sure my noise is related to the reclined rear seat cause when the seats are up the noise is almost gone and when the back of the seats is down the noise is there in every pot whole/bump. Didnt have the time yet to check but eventually I will. Quote Link to comment Share on other sites More sharing options...
oskar27 Posted May 1 Author Report Share Posted May 1 Finally the mystery noise is solved, had a chance to go to the dealer and the noise comes from my shock absorber. Dealer will order the parts and will call me to have the work done. Many thanks to all for the help. 3 2 Quote Link to comment Share on other sites More sharing options...
