AntB Posted December 2, 2023 Report Share Posted December 2, 2023 Hello everyone, this is my first post here and I have some problems ;). In my Ford Edge Sel 2022 2.0EB (US version) it does not detect the remote control and tire pressure sensors. The first problem is not related to the remote control itself (it has a good battery, it is encoded as an admin key). The remote control itself is recognized in the backup slot inside the center console, so I can drive. The second problem remains despite using the procedure with tpms activator. Perhaps both problems are related to one sensor: https://www.searchfordparts.com/oem-parts/ford-tire-pressure-monitoring-system-tpms-receiver-ml3z15607x?c=Zz1lbGVjdHJpY2FsJnM9a2V5bGVzcy1lbnRyeS1jb21wb25lbnRzJmw9MyZuPUFzc2VtYmxpZXMgUGFnZSZhPWZvcmQmbz1lZGdlJnk9MjAyMiZ0PXNlbCZlPTItMGwtbDQtZ2Fz Where to locate it - do you have any photos, diagrams and installation diagrams? Or maybe some other tips? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted December 2, 2023 Report Share Posted December 2, 2023 The fob does the following: button presses to lock/unlock, does that work? proximity lock unlock (hand behind handle to unlock), does that work? once in the cabin sensed and allows starting (this doesn't work) If it is just the inside proximity and it saying key not found unless you use the emergency backup slot, and TPMS doesn't work, I do think that module you link to does both inside the vehicle. This thread shows the RTM location on a 2018. The module is different year to year, but probably in the same location. 1 Quote Link to comment Share on other sites More sharing options...
AntB Posted December 2, 2023 Author Report Share Posted December 2, 2023 Quote button presses to lock/unlock, does that work? No Quote proximity lock unlock (hand behind handle to unlock), does that work? No Quote once in the cabin sensed and allows starting (this doesn't work) No This should be the matching part: https://dealer.parts.ford.com/shop/en/us/electrical/control-modules/transceiver-keyless-entry-receiver-p-ml3z15607k I'll try to find it and check the RTM, thanks for your help. 1 Quote Link to comment Share on other sites More sharing options...
edjunior Posted December 3, 2023 Report Share Posted December 3, 2023 Do you still have a factory warranty on this? Why don't you take it in and make some good use of the warranty? Quote Link to comment Share on other sites More sharing options...
1004ron Posted December 3, 2023 Report Share Posted December 3, 2023 9 hours ago, edjunior said: Do you still have a factory warranty on this? Why don't you take it in and make some good use of the warranty? AntB is in Poland. AntB please add location (Poland) and your vehicle Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
AntB Posted December 3, 2023 Author Report Share Posted December 3, 2023 3 hours ago, 1004ron said: AntB is in Poland. AntB please add location (Poland) and your vehicle Model/Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ Signature updated. The car is no longer under warranty. My Edge was imported to Europe from the USA, hence the problem with finding a specialist with appropriate information such as diagrams of modules and sensors. And in this topic I will let you know if the problem is the RTM in the headliner at the back of the car. 1 Quote Link to comment Share on other sites More sharing options...
edjunior Posted December 4, 2023 Report Share Posted December 4, 2023 10 hours ago, AntB said: Signature updated. The car is no longer under warranty. My Edge was imported to Europe from the USA, hence the problem with finding a specialist with appropriate information such as diagrams of modules and sensors. And in this topic I will let you know if the problem is the RTM in the headliner at the back of the car. Ah..got it. Thanks for the clarification. I can see this certaily being an issue. 1 Quote Link to comment Share on other sites More sharing options...
AntB Posted January 22, 2024 Author Report Share Posted January 22, 2024 On 12/2/2023 at 10:01 PM, AntB said: This should be the matching part: https://dealer.parts.ford.com/shop/en/us/electrical/control-modules/transceiver-keyless-entry-receiver-p-ml3z15607k I'll try to find it and check the RTM, thanks for your help. The problem was exactly the module number ML3Z-15607-K (designation on the part itself ML3T-15K619-JA). After replacing it, all problems disappeared. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 17, 2024 Report Share Posted April 17, 2024 On 1/22/2024 at 3:08 PM, AntB said: The problem was exactly the module number ML3Z-15607-K (designation on the part itself ML3T-15K619-JA). After replacing it, all problems disappeared. Thanks. What do you mean by designation on the part itself? Was ML3T-15K619-JA on the sticker of the part, but ML3Z-15607-K was on the website? Quote Link to comment Share on other sites More sharing options...
AntB Posted April 17, 2024 Author Report Share Posted April 17, 2024 11 minutes ago, Wubster100 said: What do you mean by designation on the part itself? Was ML3T-15K619-JA on the sticker of the part, but ML3Z-15607-K was on the website? 1 Quote Link to comment Share on other sites More sharing options...
