TSB 24-2345 - 2015-2017 Edge 2.7L EcoBoost, 2016-2017 MKX 2.7L EcoBoost + Other Models - Oil Pan Leaking
Haz
This TSB has been superseded by TSB 24-2345, which is posted below...
Document download link (corrected document)> TSB 23-2338 - 2.7L-3.0L EcoBoost - Oil Pan Leaking - 10-30-2023.pdf
TECHNICAL SERVICE BULLETIN
2.7L/3.0L EcoBoost - Oil Pan Leaking
23-2338
30 October 2023
This bulletin supersedes 22-2181.
Model:
Ford
2015-2017 Edge
Engine: 2.7L EcoBoost
2017 Fusion
Lincoln
2017 Continental
Engine: 3.0L EcoBoost
2016-2017 MKX
2017 MKZ
Summary
This article supersedes TSB 22-2181 to update the Service Procedure and Part List.
Issue: Some 2015-2017 Edge, 2016-2017 MKX, 2017 Fusion/MKZ/Continental vehicles equipped with a 2.7L EcoBoost or 3.0L EcoBoost engine may exhibit an oil leak from the engine oil pan RTV seal. This may be due to a lack of RTV adhesion. To correct the condition, follow the Service Procedure to replace the valve covers and replace the factory oil pan with a press in place gasket style oil pan.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• One of the following vehicles:
- 2015-2017 Edge
- 2016-2017 MKX
- 2017 Continental/Fusion/MKZ
• 2.7L/3.0L Engine
• Oil leak from the oil pan RTV seal
Parts
Service Part Number Quantity Description Unit of Issue Piece Quantity Note
9W7Z-19B596-A 1 Seal Kit - A/C Compressor Gasket And O-Ring, 1/2 Inch (Edge/MKX)
DL3Z-19B596-B 1 Seal Kit - A/C Compressor Gasket And O-Ring, 5/8 Inch (Continental 2.7L)
HL3Z-19B596-A 1 Seal Kit - A/C O-Rings - 3/4 Inch, 1/2 Inch, 5/8 Inch And 3/8 Inch (Fusion/MKZ And Continental 3.0L)
DS7Z-19B596-A 1 Seal Kit - A/C Compressor Gaskets 8 mm, 1/2 Inch, 5/8 Inch (All Models)
KT4Z-6675-E 1 Oil Pan 1 1 Oil pan is different than the original part
KU2Z-6731-A 1 Oil Filter Element And O-Ring Seals 1 1 O-ring seals are only available as an assembly with the oil filter
W714265-S442 1 Left Catalytic Converter Nuts 4 2
FT4Z-6626-A 1 Oil Pump Seal 1 1
BL3Z-9450-A 1 Catalytic Converter Gasket 1 1
FT4Z-6582-F 1 Right Valve Cover 1 1
FT4Z-6582-G 1 Left Valve Cover 1 1
YN-33-A As Needed R-1234yf Refrigerant (All Markets Except Canada)
HS7Z-19B519-BA As Needed R-1234yf Refrigerant (Canada Only)
YN-35 As Needed Refrigerant Oil
ZC-30-A As Needed Motorcraft® Gasket Remover
TA-357 As Needed Motorcraft® High Performance Engine RTV Silicone
XO- 5W30-Q1SP As Needed Motorcraft® SAE 5W-30 Synthetic Blend Motor Oil (All Markets Except Canada)
CXO-5W30-LSP6 As Needed Motorcraft® SAE 5W-30 Super Premium Motor Oil (Canada Only)
PM-4-A As Needed Motorcraft® Metal Brake Parts Cleaner (Compliant With Low Volatile Organic Compound Requirements As Required In Some USA States)
PM-4-B As Needed Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Volatile Organic Compound Requirements)
VC-13-G As Needed Motorcraft® Yellow Concentrated Antifreeze/Coolant (All Markets Except Canada)
CVC-13-G As Needed Motorcraft® Yellow Concentrated Antifreeze/Coolant (Canada Only)
Parts
Parts To Inspect And Replace Only If Necessary
Service Part Number Quantity Description Note
1X4Z-9E936-AA If Needed Coil Boot (Fusion 2.7L)
FU7Z-12A402-A If Needed Coil Boot (MKX 2.7L)
FT4Z-6A832-C If Needed Oil Filter And Cap Assembly Kit Oil cap is only available as an assembly with the oil filter
Quantity refers to the amount of the service part number package(s) required to repair the vehicle.
Unit of Issue refers to the number of individual pieces included in a service part number package.
Piece Quantity refers to the total number of individual pieces required to repair the vehicle.
As Needed indicates the amount of the part may vary and/or is not a whole number. Parts can be billed out as non-whole numbers, including less than 1.
If Needed indicates the part is not mandatory.
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description Operation No. Time
2017 Continental 2.7L/3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338A 2.9 Hrs.
2017 Continental 2.7L/3.0L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338B 7.2 Hrs.
2015-2017 Edge, 2016-2017 MKX 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338C 3.0 Hrs.
2015-2017 Edge, 2016-2017 MKX 2.7L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338D 7.6 Hrs.
2017 Fusion 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 232338E 3.1 Hrs.
2017 Fusion 2.7L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338F 7.4 Hrs.
2017 MKZ 3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 232338G 3.1 Hrs.
2017 MKZ 3.0L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338H 8.1 Hrs.
Repair/Claim Coding
Causal Part: 6675
Condition Code: D8
Service Procedure
NOTE: There are internal positive crankcase ventilation (PCV) system check valves built into some oil pans and valve covers. Follow the Service Procedure to make sure replacement parts are properly chosen to maintain an operable PCV system.
1. Inspect the valve cover design around the ignition coils on both sides. Does the coil location have the extended plastic protective ribbing as shown in red? (Figure 1)
Figure 1
(1). Yes - proceed to Step 3.
(2). No - proceed to Step 2.
2. Replace both valve covers. Refer to Workshop Manual (WSM), Section 303-01, Removal and Installation > Valve Cover LH and Valve Cover RH. Proceed to Step 3.
3. Remove and discard the oil pan and oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan.
4. Clean and prepare the engine sealing surface. Refer to WSM, Section 303-00 General Procedures.
5. Install the new oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan.
6. Apply a 18 mm (0.708 in.) bead of Motorcraft® High Performance Engine RTV Silicone to the oil pan where the front cover-to-cylinder block joint areas contact. (Figure 2)
Figure 2
NOTE: The new oil pan does not require the use of Motorcraft® High Performance Engine RTV Silicone in any other location.
7. Verify the correct orientation of the new press in place gasket and install the new oil pan. Refer to the WSM, Section 303-01, Removal and Installation > Oil Pan.
© 2023 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Edited by Haz
  • Like 5
Does this say there is a new oil pan? With a built in gasket? I was just going to deal with the leaking pan since it's been replaced at least twice but if there's a better replacement now, I might have to call. I see the Warranty Status section but I don't understand it. Do you know if this covers anything with the issue? I just hit 69k miles on a 2017
@Haz
As usual, great updates, thanks for all your contributions.
It's about time they made an updated oil pan with a gasket for the older 2.7s.
I went through the TSB, but I couldn't find the figure 1 in the PDF, is there any attachment to the TSB?
Edited by omar302
Omar302: Good catch on the absent referred-to illustration!
I have edited and revised my original post.
The originally released TSB 23-2338 lacked imagery, however, I checked the Professional Technician System website today and the missing images are now included, which  clarifies the 'new' oil pan and preformed perimeter gasket.
I say 'new', because I find the KT4Z-6675-E oil pan part number on several online sites associated with 2019 Edge-Nautilus & 2019-2023 F-150 2.7L EcoBoost installations, as well as the second image in the TSB comes straight from the Oil Pan Removal and Installation procedure in the 2019-2024 Edge-Nautilus & 2019-2023 F-150 Workshop Manuals.
Ford's online parts-selling site includes this page for KT4Z6675E, which lacks any preformed perimeter in the illustration, and identifies the oil pan as fitting 2019 Edge & Nautilus, so FordParts is not quite ready for Prime Time on this...
Link to this FordParts webpage
1158524577_TSB-2338sReplacementOilPanKT4Z6675E-FordParts_com.thumb.jpg.0aa738211c566f53520d953a94a2653c.jpg
FordParts' webpage for the KT4Z6675D Oil Pan provides the previously expected illustration and indicates this part fits 2019-2024 Edge...
1339329111_2019-2024EdgeOilPanKT4Z6675D-FordParts_com.thumb.jpg.64557e503f09704f59606e5ba857d50f.jpg
FordParts informs on this associated JT4Z6710A preformed perimeter Oil Pan Gasket, described as fitting 2019-2024 Ford Edge, 2019-2024 F-150-Lobo, 2021-2024 Bronco, and 2024 Ranger...
1647971558_2019-2024FordEdge2019-2024F-150-Lobo2021-2024Bronco2024RangerPerimeterOilPanGasket.thumb.jpg.cb40c45395ccda2e43d12b347be9ba6d.jpg
...and on the associated KT4Z6710B internal Oil Pan Gasket, described as fitting 2019 Lincoln Nautilus and 2019-2024 Ford Edge...
1614946866_2019LincolnNautilus2019-2024FordEdgeKT4Z6710BInternalOilPanGasket.thumb.jpg.967e120f04addf29117c77b4184e8388.jpg
The following 2019 Edge Workshop Manual section may be a useful supplement to TSB 23-2338...
Document download link> Oil Pan - Removal and Installation - 2.7L EcoBoost - 2019 Edge Workshop Manual.pdf
bscott99: If you do not have any Ford/FordProtect Extended Service Plan (ESP) and your Edge's Powertrain Warranty expired at 5 Years/60,000 miles, but your Edge has received two replacement Oil Pans, then it is worth seeking coverage for the TSB 23-2338 Service on the basis of those prior warranty-covered (?) replacements under the Service Parts Warranty, especially if its 2-year timeframe fits...
Document download link> Ford-Motorcraft Service Parts Limited Warranty Summary - June 2023.pdf
Good luck!
  • Like 3
Sorry but I'm a little confused on the vehicle application, if someone could clarify I would appreciate it. The TSB says 2015 - 2017 Edge would be eligible for the new oil pan. I thought later years were using the rtv sealant on the oil pan also?  Unless it's referring to those years also needing the valve covers.
I only have about 35,500.miles on my 2019 but so far have not noticed any oil leaks.
This TSB is only applicable to 2015-2017.  It’s not an extended warranty - it’s subject to the normal warranty coverage if you have a leak.  There could be a different TSB for the 2019s or they may already have the updated pan.
  • Thanks 1
My guess is that this new version oil pan (KT4Z-6675-E) is for use on all (2015+), however, for the 2015-2017 it would require the new Valve covers, my guess for the PCV Check Valve that is missing from the new oil pans.
  • 9 months later...
This job is quite cramped. The reason for all the leaks is that there are two passageways with higher pressure in the oil pan. I recommend using a Fel-Pro gasket and applying supplementary high-performance RTV or Ultra Black sealant near the cavities and the timing cover.
Bank 2 Cat: Remove the two 15mm nuts on the Bank 2 catalytic converter.
A/C Compressor: Partially unbolt the A/C compressor using a 13mm wrench, allowing about 1 inch of clearance.
Undercarriage: Lower the undercarriage by 3 inches on the passenger side by removing the three 21mm bolts (one of which is for the power steering).
Engine Mount: Remove the top engine mount bolt.
Lift the Engine: Use an engine hoist or jack to lift the engine slightly to gain better access.
Before installation, allow the oil to drip for 24 hours. When mounting the oil pan, slide the downpipe back and forth to align it. Insert a clean rag into three separate areas to prevent oil seepage. Then, quickly remove said rags and install the oil pan with RTV and the gasket.
  • Haz changed the title to TSB 24-2345 - 2015-2017 Edge 2.7L EcoBoost, 2016-2017 MKX 2.7L EcoBoost + Other Models - Oil Pan Leaking
TSB 24-2345 - 2.7L EcoBoost & 3.0L EcoBoost - Oil Pan Leaking.pdf
24-2345
25 November 2024
This bulletin supersedes 23-2338. Reason for update: revised Service Procedure, update Part List
Model:
Ford
2015-2017 Edge
2017 Fusion
Lincoln
2017 Continental
2016-2017 MKX
2017 MKZ
Markets: North American markets only
Issue: Some 2015-2017 Edge, 2016-2017 MKX, 2017 Fusion/MKZ/Continental vehicles equipped with a 2.7L EcoBoost or 3.0L EcoBoost engine may exhibit an oil leak from the engine oil pan RTV seal. This may be due to a lack of RTV adhesion. To correct the condition, follow the Service Procedure to replace the factory oil pan with a press in place gasket style oil pan.
• One of the following vehicle lines:
- 2015-2017 Edge
- 2016-2017 MKX
• 2.7L/3.0L EcoBoost engine
Parts
Service Part Number Claim Quantity Package Order Quantity Number in Package Description
FT4Z-6675-D 1 1 1 Oil Pan
FL3Z-6710-B 1 1 1 Oil Pan Gasket
KU2Z-6731-A 1 1 1 Oil Filter Element And O-Ring Seals
FT4Z-6A832-C 1 1 1 Oil Filter and Cap Assembly Kit
9W7Z-19B596-A 1 1 1 Seal Kit - A/C Compressor Gasket And O-Ring, 1/2 In. (Edge/MKX Only)
DL3Z-19B596-B 1 1 1 Seal Kit - A/C Compressor Gasket And O-Ring, 5/8 In. (Continental 2.7L Only)
DS7Z-19B596-A 1 1 1 Seal Kit - A/C Compressor Gaskets 8 mm, 1/2 In., 5/8 In. (All Models)
HL3Z-19B596-A 1 1 1 Seal Kit - A/C O-Rings - 3/4 In., 1/2 In., 5/8 In. and 3/8 In. (Fusion/MKZ/Continental 3.0L)
FT4Z-6626-A 1 1 1 Oil Pump Seal
W714265-S442 1 1 4 Left Catalytic Converter Nuts
BL3Z-9450-A 1 1 1 Catalytic Converter Gasket
Parts - Parts To Inspect And Replace Only If Necessary
ZC-30-A Only If Necessary Only If Necessary   Motorcraft® Gasket Remover
TA-357 Only If Necessary Only If Necessary   Motorcraft® High Performance Engine RTV Silicone
XO- 5W30-Q1SP Only If Necessary Only If Necessary   Motorcraft® SAE 5W-30 Synthetic Blend Motor Oil (All Markets Except Canada)
CXO-5W30-LSP6 Only If Necessary Only If Necessary   Motorcraft® SAE 5W-30 Super Premium Motor Oil (Canada Only)
VC-13-G Only If Necessary Only If Necessary   Motorcraft® Yellow Concentrated Antifreeze/Coolant (All Markets Except Canada)
CVC-13-G Only If Necessary Only If Necessary   Motorcraft® Yellow Concentrated Antifreeze/Coolant (Canada Only)
PM-4-A Only If Necessary Only If Necessary   Motorcraft® Brake Parts Cleaner - VOC Compliant (All Markets Except Canada)
PM-4-B Only If Necessary Only If Necessary   Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Low Volatile Organic Compound [VOC] Requirements) (All Markets Except Canada)
CPM-4-A Only If Necessary Only If Necessary   Motorcraft® Brake Parts Cleaner - VOC Compliant (Canada Only)
Claim Quantity refers to the total number of individual pieces required to repair the vehicle.
Package Order Quantity refers to the amount of the service part number package(s) required to repair the vehicle.
Number In Package refers to the number of individual pieces included in a service part number package.
Only If Necessary indicates the part is not mandatory. Refer to the Service Procedure to determine the inspection/inclusion criteria.
Labor Times
2017 Continental 2.7L/3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 242345A 3.1 Hrs.
2015-2017 Edge, 2016-2017 MKX 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 242345B 3.2 Hrs.
2017 Fusion 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 242345C 3.2 Hrs.
2017 MKZ 3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 242345D 3.2 Hrs.
Repair/Claim Coding
Causal Part: 6675
Condition Code: D8
Service Procedure
1. Remove and discard the oil pan and oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan.
2. Clean and prepare the engine sealing surface. Refer to WSM, Section 303-00 General Procedures.
3. Install the new oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan.
4. Verify the correct orientation of the new press in place gasket and install the new oil pan. Refer to the WSM, Section 303-01, Removal and Installation > Oil Pan.
(1). Apply an 18 mm bead of Motorcraft® High Performance Engine RTV Silicone at the T-joints, where the ladder frame meets the front cover (Figure 1)
Figure 1
© 2024 Ford Motor Company
Thanks as usual for your updates and contributions.
Seems now there is another new Oil Pan with with a separate gasket and does not require replacement of the valve covers. That is good and makes for a cheaper fix.
Now we need an extended warranty coverage and at least a one time replacement to the new design pan.
Mine started to leak, but isn't significant and still doesn't drip on the floor.
@Haz
Can you please help with the manual procedures for changing the oil pan for the 2016 Edge Sport and 2016 MKX (2.7 EcoBoost)?
I ordered a set of parts to fix the oil pan leak on my Edge which started to develop a small leak, but as the parts arrived we got a friend with an MKX that has a much more serious leak. So we'll fix his first then mine.
  • 2 months later...
@DBEDGE23: The 2016 2.7L EcoBoost Workshop Manual documents attached immediately-above also apply to your 2015 2.7L EcoBoost Edge Sport.
Ford Service Time Labor Standard - 2015 Edge AWD
Gasket Set or Oil Pan (In Chassis) (6675/ 6710/ 6781) - Remove and Install or Replace - 2.7L EcoBoost = 3.1 hours
Includes clean internally mounted oil pump pick-up tube and screen and replace oil filter when directed by workshop manual.
Good luck!
