Haz Posted October 31, 2023 Report Share Posted October 31, 2023 (edited) This TSB has been superseded by TSB 24-2345, which is posted below... Document download link (corrected document)> TSB 23-2338 - 2.7L-3.0L EcoBoost - Oil Pan Leaking - 10-30-2023.pdf TECHNICAL SERVICE BULLETIN 2.7L/3.0L EcoBoost - Oil Pan Leaking 23-2338 30 October 2023 This bulletin supersedes 22-2181. Model: Ford 2015-2017 Edge Engine: 2.7L EcoBoost 2017 Fusion Engine: 2.7L EcoBoost Lincoln 2017 Continental Engine: 2.7L EcoBoost Engine: 3.0L EcoBoost 2016-2017 MKX Engine: 2.7L EcoBoost 2017 MKZ Engine: 3.0L EcoBoost Summary This article supersedes TSB 22-2181 to update the Service Procedure and Part List. Issue: Some 2015-2017 Edge, 2016-2017 MKX, 2017 Fusion/MKZ/Continental vehicles equipped with a 2.7L EcoBoost or 3.0L EcoBoost engine may exhibit an oil leak from the engine oil pan RTV seal. This may be due to a lack of RTV adhesion. To correct the condition, follow the Service Procedure to replace the valve covers and replace the factory oil pan with a press in place gasket style oil pan. Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria: • One of the following vehicles: - 2015-2017 Edge - 2016-2017 MKX - 2017 Continental/Fusion/MKZ • 2.7L/3.0L Engine • Oil leak from the oil pan RTV seal Parts Service Part Number Quantity Description Unit of Issue Piece Quantity Note 9W7Z-19B596-A 1 Seal Kit - A/C Compressor Gasket And O-Ring, 1/2 Inch (Edge/MKX) DL3Z-19B596-B 1 Seal Kit - A/C Compressor Gasket And O-Ring, 5/8 Inch (Continental 2.7L) HL3Z-19B596-A 1 Seal Kit - A/C O-Rings - 3/4 Inch, 1/2 Inch, 5/8 Inch And 3/8 Inch (Fusion/MKZ And Continental 3.0L) DS7Z-19B596-A 1 Seal Kit - A/C Compressor Gaskets 8 mm, 1/2 Inch, 5/8 Inch (All Models) KT4Z-6675-E 1 Oil Pan 1 1 Oil pan is different than the original part KU2Z-6731-A 1 Oil Filter Element And O-Ring Seals 1 1 O-ring seals are only available as an assembly with the oil filter W714265-S442 1 Left Catalytic Converter Nuts 4 2 FT4Z-6626-A 1 Oil Pump Seal 1 1 BL3Z-9450-A 1 Catalytic Converter Gasket 1 1 FT4Z-6582-F 1 Right Valve Cover 1 1 FT4Z-6582-G 1 Left Valve Cover 1 1 YN-33-A As Needed R-1234yf Refrigerant (All Markets Except Canada) HS7Z-19B519-BA As Needed R-1234yf Refrigerant (Canada Only) YN-35 As Needed Refrigerant Oil ZC-30-A As Needed Motorcraft® Gasket Remover TA-357 As Needed Motorcraft® High Performance Engine RTV Silicone XO- 5W30-Q1SP As Needed Motorcraft® SAE 5W-30 Synthetic Blend Motor Oil (All Markets Except Canada) CXO-5W30-LSP6 As Needed Motorcraft® SAE 5W-30 Super Premium Motor Oil (Canada Only) PM-4-A As Needed Motorcraft® Metal Brake Parts Cleaner (Compliant With Low Volatile Organic Compound Requirements As Required In Some USA States) PM-4-B As Needed Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Volatile Organic Compound Requirements) VC-13-G As Needed Motorcraft® Yellow Concentrated Antifreeze/Coolant (All Markets Except Canada) CVC-13-G As Needed Motorcraft® Yellow Concentrated Antifreeze/Coolant (Canada Only) Parts Parts To Inspect And Replace Only If Necessary Service Part Number Quantity Description Note 1X4Z-9E936-AA If Needed Coil Boot (Fusion 2.7L) FU7Z-12A402-A If Needed Coil Boot (MKX 2.7L) FT4Z-6A832-C If Needed Oil Filter And Cap Assembly Kit Oil cap is only available as an assembly with the oil filter Quantity refers to the amount of the service part number package(s) required to repair the vehicle. Unit of Issue refers to the number of individual pieces included in a service part number package. Piece Quantity refers to the total number of individual pieces required to repair the vehicle. As Needed indicates the amount of the part may vary and/or is not a whole number. Parts can be billed out as non-whole numbers, including less than 1. If Needed indicates the part is not mandatory. Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. Labor Times Description Operation No. Time 2017 Continental 2.7L/3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338A 2.9 Hrs. 2017 Continental 2.7L/3.0L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338B 7.2 Hrs. 2015-2017 Edge, 2016-2017 MKX 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338C 3.0 Hrs. 2015-2017 Edge, 2016-2017 MKX 2.7L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338D 7.6 Hrs. 2017 Fusion 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 232338E 3.1 Hrs. 2017 Fusion 2.7L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338F 7.4 Hrs. 2017 MKZ 3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 232338G 3.1 Hrs. 2017 MKZ 3.0L EcoBoost: Inspect And Replace Both Valve Covers And The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 232338H 8.1 Hrs. Repair/Claim Coding Causal Part: 6675 Condition Code: D8 Service Procedure NOTE: There are internal positive crankcase ventilation (PCV) system check valves built into some oil pans and valve covers. Follow the Service Procedure to make sure replacement parts are properly chosen to maintain an operable PCV system. 1. Inspect the valve cover design around the ignition coils on both sides. Does the coil location have the extended plastic protective ribbing as shown in red? (Figure 1) Figure 1 (1). Yes - proceed to Step 3. (2). No - proceed to Step 2. 2. Replace both valve covers. Refer to Workshop Manual (WSM), Section 303-01, Removal and Installation > Valve Cover LH and Valve Cover RH. Proceed to Step 3. 3. Remove and discard the oil pan and oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan. 4. Clean and prepare the engine sealing surface. Refer to WSM, Section 303-00 General Procedures. 5. Install the new oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan. 6. Apply a 18 mm (0.708 in.) bead of Motorcraft® High Performance Engine RTV Silicone to the oil pan where the front cover-to-cylinder block joint areas contact. (Figure 2) Figure 2 NOTE: The new oil pan does not require the use of Motorcraft® High Performance Engine RTV Silicone in any other location. 7. Verify the correct orientation of the new press in place gasket and install the new oil pan. Refer to the WSM, Section 303-01, Removal and Installation > Oil Pan. © 2023 Ford Motor Company All rights reserved. NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources. Edited November 26, 2024 by Haz 5 Quote Link to comment Share on other sites More sharing options...
bscott94 Posted October 31, 2023 Report Share Posted October 31, 2023 Does this say there is a new oil pan? With a built in gasket? I was just going to deal with the leaking pan since it's been replaced at least twice but if there's a better replacement now, I might have to call. I see the Warranty Status section but I don't understand it. Do you know if this covers anything with the issue? I just hit 69k miles on a 2017 Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 2, 2023 Report Share Posted November 2, 2023 (edited) On 10/31/2023 at 2:17 PM, Haz said: 1. Inspect the valve cover design around the ignition coils on both sides. Does the coil location have the extended plastic protective ribbing as shown in red? (Figure 1) (1). Yes - proceed to Step 3. (2). No - proceed to Step 2. 2. Replace both valve covers. Refer to Workshop Manual (WSM), Section 303-01, Removal and Installation > Valve Cover LH and Valve Cover RH. Proceed to Step 3. @Haz As usual, great updates, thanks for all your contributions. It's about time they made an updated oil pan with a gasket for the older 2.7s. I went through the TSB, but I couldn't find the figure 1 in the PDF, is there any attachment to the TSB? Edited November 2, 2023 by omar302 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted November 3, 2023 Author Report Share Posted November 3, 2023 Omar302: Good catch on the absent referred-to illustration! I have edited and revised my original post. The originally released TSB 23-2338 lacked imagery, however, I checked the Professional Technician System website today and the missing images are now included, which clarifies the 'new' oil pan and preformed perimeter gasket. I say 'new', because I find the KT4Z-6675-E oil pan part number on several online sites associated with 2019 Edge-Nautilus & 2019-2023 F-150 2.7L EcoBoost installations, as well as the second image in the TSB comes straight from the Oil Pan Removal and Installation procedure in the 2019-2024 Edge-Nautilus & 2019-2023 F-150 Workshop Manuals. Ford's online parts-selling site includes this page for KT4Z6675E, which lacks any preformed perimeter in the illustration, and identifies the oil pan as fitting 2019 Edge & Nautilus, so FordParts is not quite ready for Prime Time on this... Link to this FordParts webpage FordParts' webpage for the KT4Z6675D Oil Pan provides the previously expected illustration and indicates this part fits 2019-2024 Edge... Link to this FordParts webpage FordParts informs on this associated JT4Z6710A preformed perimeter Oil Pan Gasket, described as fitting 2019-2024 Ford Edge, 2019-2024 F-150-Lobo, 2021-2024 Bronco, and 2024 Ranger... Link to this FordParts webpage ...and on the associated KT4Z6710B internal Oil Pan Gasket, described as fitting 2019 Lincoln Nautilus and 2019-2024 Ford Edge... Link to this FordParts webpage The following 2019 Edge Workshop Manual section may be a useful supplement to TSB 23-2338... Document download link> Oil Pan - Removal and Installation - 2.7L EcoBoost - 2019 Edge Workshop Manual.pdf bscott99: If you do not have any Ford/FordProtect Extended Service Plan (ESP) and your Edge's Powertrain Warranty expired at 5 Years/60,000 miles, but your Edge has received two replacement Oil Pans, then it is worth seeking coverage for the TSB 23-2338 Service on the basis of those prior warranty-covered (?) replacements under the Service Parts Warranty, especially if its 2-year timeframe fits... Document download link> Ford-Motorcraft Service Parts Limited Warranty Summary - June 2023.pdf Good luck! 3 Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted November 5, 2023 Report Share Posted November 5, 2023 Sorry but I'm a little confused on the vehicle application, if someone could clarify I would appreciate it. The TSB says 2015 - 2017 Edge would be eligible for the new oil pan. I thought later years were using the rtv sealant on the oil pan also? Unless it's referring to those years also needing the valve covers. I only have about 35,500.miles on my 2019 but so far have not noticed any oil leaks. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted November 5, 2023 Report Share Posted November 5, 2023 2 hours ago, kruzr1 said: Sorry but I'm a little confused on the vehicle application, if someone could clarify I would appreciate it. The TSB says 2015 - 2017 Edge would be eligible for the new oil pan. I thought later years were using the rtv sealant on the oil pan also? Unless it's referring to those years also needing the valve covers. I only have about 35,500.miles on my 2019 but so far have not noticed any oil leaks. This TSB is only applicable to 2015-2017. It’s not an extended warranty - it’s subject to the normal warranty coverage if you have a leak. There could be a different TSB for the 2019s or they may already have the updated pan. 2 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted November 5, 2023 Author Report Share Posted November 5, 2023 (edited) With appreciation to akirby for jogging my memory on the previously posted... TSB 23-2075 - 2018-2019 Edge, 2018 MKX, 2019 Nautilus, 2.7L EcoBoost Built On or Before August 1, 2019 - Oil Pan Leaking + Other Models With 2.7L & 3.0L Ecoboost Good luck! Edited November 5, 2023 by Haz 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 5, 2023 Report Share Posted November 5, 2023 (edited) NVM looks like a new oil pan finally spec'd instead of new seal + 24 hr wait ... Edited November 5, 2023 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted November 6, 2023 Author Report Share Posted November 6, 2023 I neglected to include... Link to this FordParts webpage Link to this FordParts webpage Good luck! 3 Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 6, 2023 Report Share Posted November 6, 2023 On 11/4/2023 at 12:14 AM, Haz said: Omar302: Good catch on the absent referred-to illustration! I have edited and revised my original post. The originally released TSB 23-2338 lacked imagery, however, I checked the Professional Technician System website today and the missing images are now included, which clarifies the 'new' oil pan and preformed perimeter gasket. I say 'new', because I find the KT4Z-6675-E oil pan part number on several online sites associated with 2019 Edge-Nautilus & 2019-2023 F-150 2.7L EcoBoost installations, as well as the second image in the TSB comes straight from the Oil Pan Removal and Installation procedure in the 2019-2024 Edge-Nautilus & 2019-2023 F-150 Workshop Manuals. My guess is that this new version oil pan (KT4Z-6675-E) is for use on all (2015+), however, for the 2015-2017 it would require the new Valve covers, my guess for the PCV Check Valve that is missing from the new oil pans. 1 Quote Link to comment Share on other sites More sharing options...
dg8 Posted August 13, 2024 Report Share Posted August 13, 2024 This job is quite cramped. The reason for all the leaks is that there are two passageways with higher pressure in the oil pan. I recommend using a Fel-Pro gasket and applying supplementary high-performance RTV or Ultra Black sealant near the cavities and the timing cover. Bank 2 Cat: Remove the two 15mm nuts on the Bank 2 catalytic converter. A/C Compressor: Partially unbolt the A/C compressor using a 13mm wrench, allowing about 1 inch of clearance. Undercarriage: Lower the undercarriage by 3 inches on the passenger side by removing the three 21mm bolts (one of which is for the power steering). Engine Mount: Remove the top engine mount bolt. Lift the Engine: Use an engine hoist or jack to lift the engine slightly to gain better access. Before installation, allow the oil to drip for 24 hours. When mounting the oil pan, slide the downpipe back and forth to align it. Insert a clean rag into three separate areas to prevent oil seepage. Then, quickly remove said rags and install the oil pan with RTV and the gasket. 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted November 26, 2024 Author Report Share Posted November 26, 2024 TSB 24-2345 - 2.7L EcoBoost & 3.0L EcoBoost - Oil Pan Leaking.pdf TECHNICAL SERVICE BULLETIN 2.7L/3.0L EcoBoost - Oil Pan Leaking 24-2345 25 November 2024 This bulletin supersedes 23-2338. Reason for update: revised Service Procedure, update Part List Model: Ford 2015-2017 Edge Engine: 2.7L EcoBoost 2017 Fusion Engine: 2.7L EcoBoost Lincoln 2017 Continental Engine: 2.7L EcoBoost Engine: 3.0L EcoBoost 2016-2017 MKX Engine: 2.7L EcoBoost 2017 MKZ Engine: 3.0L EcoBoost Markets: North American markets only Issue: Some 2015-2017 Edge, 2016-2017 MKX, 2017 Fusion/MKZ/Continental vehicles equipped with a 2.7L EcoBoost or 3.0L EcoBoost engine may exhibit an oil leak from the engine oil pan RTV seal. This may be due to a lack of RTV adhesion. To correct the condition, follow the Service Procedure to replace the factory oil pan with a press in place gasket style oil pan. Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria: • One of the following vehicle lines: - 2015-2017 Edge - 2016-2017 MKX - 2017 Continental/Fusion/MKZ • 2.7L/3.0L EcoBoost engine • Oil leak from the oil pan RTV seal Parts Service Part Number Claim Quantity Package Order Quantity Number in Package Description FT4Z-6675-D 1 1 1 Oil Pan FL3Z-6710-B 1 1 1 Oil Pan Gasket KU2Z-6731-A 1 1 1 Oil Filter Element And O-Ring Seals FT4Z-6A832-C 1 1 1 Oil Filter and Cap Assembly Kit 9W7Z-19B596-A 1 1 1 Seal Kit - A/C Compressor Gasket And O-Ring, 1/2 In. (Edge/MKX Only) DL3Z-19B596-B 1 1 1 Seal Kit - A/C Compressor Gasket And O-Ring, 5/8 In. (Continental 2.7L Only) DS7Z-19B596-A 1 1 1 Seal Kit - A/C Compressor Gaskets 8 mm, 1/2 In., 5/8 In. (All Models) HL3Z-19B596-A 1 1 1 Seal Kit - A/C O-Rings - 3/4 In., 1/2 In., 5/8 In. and 3/8 In. (Fusion/MKZ/Continental 3.0L) FT4Z-6626-A 1 1 1 Oil Pump Seal W714265-S442 1 1 4 Left Catalytic Converter Nuts BL3Z-9450-A 1 1 1 Catalytic Converter Gasket Parts - Parts To Inspect And Replace Only If Necessary Service Part Number Claim Quantity Package Order Quantity Number in Package Description ZC-30-A Only If Necessary Only If Necessary Motorcraft® Gasket Remover TA-357 Only If Necessary Only If Necessary Motorcraft® High Performance Engine RTV Silicone XO- 5W30-Q1SP Only If Necessary Only If Necessary Motorcraft® SAE 5W-30 Synthetic Blend Motor Oil (All Markets Except Canada) CXO-5W30-LSP6 Only If Necessary Only If Necessary Motorcraft® SAE 5W-30 Super Premium Motor Oil (Canada Only) VC-13-G Only If Necessary Only If Necessary Motorcraft® Yellow Concentrated Antifreeze/Coolant (All Markets Except Canada) CVC-13-G Only If Necessary Only If Necessary Motorcraft® Yellow Concentrated Antifreeze/Coolant (Canada Only) PM-4-A Only If Necessary Only If Necessary Motorcraft® Brake Parts Cleaner - VOC Compliant (All Markets Except Canada) PM-4-B Only If Necessary Only If Necessary Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Low Volatile Organic Compound [VOC] Requirements) (All Markets Except Canada) CPM-4-A Only If Necessary Only If Necessary Motorcraft® Brake Parts Cleaner - VOC Compliant (Canada Only) Claim Quantity refers to the total number of individual pieces required to repair the vehicle. Package Order Quantity refers to the amount of the service part number package(s) required to repair the vehicle. Number In Package refers to the number of individual pieces included in a service part number package. Only If Necessary indicates the part is not mandatory. Refer to the Service Procedure to determine the inspection/inclusion criteria. Labor Times Description Operation No. Time 2017 Continental 2.7L/3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 242345A 3.1 Hrs. 2015-2017 Edge, 2016-2017 MKX 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Other Labor Operations) 242345B 3.2 Hrs. 2017 Fusion 2.7L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 242345C 3.2 Hrs. 2017 MKZ 3.0L EcoBoost: Inspect And Replace The Engine Oil Pan (Do Not Use With Any Labor Operations Outside Of This Article) 242345D 3.2 Hrs. Repair/Claim Coding Causal Part: 6675 Condition Code: D8 Service Procedure 1. Remove and discard the oil pan and oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan. 2. Clean and prepare the engine sealing surface. Refer to WSM, Section 303-00 General Procedures. 3. Install the new oil pump seal. Refer to WSM, Section 303-01, Removal and Installation > Oil Pan. 4. Verify the correct orientation of the new press in place gasket and install the new oil pan. Refer to the WSM, Section 303-01, Removal and Installation > Oil Pan. (1). Apply an 18 mm bead of Motorcraft® High Performance Engine RTV Silicone at the T-joints, where the ladder frame meets the front cover (Figure 1) NOTE: The new oil pan does not require the use of Motorcraft® High Performance Engine RTV Silicone in any other location. Figure 1 © 2024 Ford Motor Company All rights reserved. NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources. 2 Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 27, 2024 Report Share Posted November 27, 2024 21 hours ago, Haz said: This bulletin supersedes 23-2338. Reason for update: revised Service Procedure, update Part List Thanks as usual for your updates and contributions. Seems now there is another new Oil Pan with with a separate gasket and does not require replacement of the valve covers. That is good and makes for a cheaper fix. Now we need an extended warranty coverage and at least a one time replacement to the new design pan. Mine started to leak, but isn't significant and still doesn't drip on the floor. 2 Quote Link to comment Share on other sites More sharing options...
