Rogue Warrior Posted September 28, 2023 Report Share Posted September 28, 2023 Hello everyone, just purchased a 2010 Edge SEL. I have a couple of issues that I will asking questions to in the forums. Thanks. 3 Quote Link to comment Share on other sites More sharing options...
CARR142 Posted September 29, 2023 Report Share Posted September 29, 2023 Welcome!, to the forum Quote Link to comment Share on other sites More sharing options...
JPJMustang Posted October 2, 2023 Report Share Posted October 2, 2023 inherited a 2009 Ford Edge with 160m on it - just had the transmission rebuilt by AAMCO and replaced the valve cover gaskets, rear brakes and both side mirrors - love driving the vehicle Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted October 2, 2023 Report Share Posted October 2, 2023 (edited) Welcome to the Herd! Lots of friendly knowledgable folk in these forums. Be aware: * The InternalChainDriven WaterPump in these TransverseMounted V6~3.5L~DOHC Engines are a NotoriousFailureItem\NFI; be sure to keep the CoolantSystem serviced every 33kMiles\4Yrs: New ThermoStat, New ReservoirPressureCap, New Coolant, and watch for coolant leaks from the weephole on front side of the engine behind alternator, or worse "ChocolateShake" colored oil on the DipStick. * If you've got AllWheelDrive\AWD, be aware of the PowerTransferUnit\PTU and RearDifferentialUnit\RDU; again NotoriousFailureItems; both need GearOil renewed every 33kMiles\4Yrs, despite Ford claiming they have "LifeTimeFluid" & are not servicable. * Another NFI, the Radiator FanControlModule, mounted on the upper left corner of the FanCowling; tends to fail & cause AC problem & Engine overheat while idling or in stop+go traffic. Edited October 2, 2023 by DILLARD000 Quote Link to comment Share on other sites More sharing options...
JPJMustang Posted November 16, 2023 Report Share Posted November 16, 2023 thanks for the update - Im DYI What gear oil in Rear Diff and PTU? 75w-90, 90w-110? TB Quote Link to comment Share on other sites More sharing options...
JPJMustang Posted November 16, 2023 Report Share Posted November 16, 2023 Also - how hard to do the chain driven waterpump? Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted November 16, 2023 Report Share Posted November 16, 2023 1 hour ago, JPJMustang said: Also - how hard to do the chain driven waterpump? Not easy or inexpensive. Need to remove timing cover, chains, guides just to get to the pump. Very difficult access with engine in vehicle. Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted November 16, 2023 Report Share Posted November 16, 2023 1 hour ago, JPJMustang said: thanks for the update - Im DYI What gear oil in Rear Diff and PTU? 75w-90, 90w-110? TB 75w140 in PTU 75w90 in DIF Personal pref is AmsOil. Best do this every 33kMiles 4yrs or less. Quote Link to comment Share on other sites More sharing options...
JPJMustang Posted November 16, 2023 Report Share Posted November 16, 2023 (edited) did you do one? how do you hold all of the shafts in place so the chain (on and off) doesnt move the out of time? thanks for the heads up on the fluids JPJM Edited November 16, 2023 by JPJMustang Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted November 17, 2023 Report Share Posted November 17, 2023 (edited) 8 hours ago, JPJMustang said: did you do one? how do you hold all of the shafts in place so the chain (on and off) doesnt move the out of time? thanks for the heads up on the fluids JPJM Been there, done that, don't realy want to do it again. WaterPump inner gasket failed (there are two = inner + outer); blew all coolant out thru weephole on front side of block behind alternator. Was very lucky that pumps outer gasket or bearing did not fail; either would have put coolant into oil pan, made a "milkshake" & ruined the engin. Pulled Engin+Trans+PTU assembly from top. New items installed included: * WaterPump with MetalImpeller * Melling HiVol OilPump * TimingGuides+Tensioners+Chains+Sprockets+VVTSolenoids+... * New PTU, modifed with bottom Fumoto DrainValve & Hoses run from TopVentBarb & SideFillBarb to Vent+FillCan underhood between Battery+FuseBox * New Radiator & StainlessFlexHoses * New RadiatorFanControlModule\FCM * New Half+FullSpeed DualTempSwitch wired in parallel as backup if notorious FCM fails again. * ... Before taking any Timing components out, put these jigs/clamps in place on both CamShafts: Timng CamShaft Jigs\Clamps specificly for2007~2010 V6~3.5L~DOHC Engin ATPEAM# AP-04-2619 About $25 on "the river or the bay". Edited November 17, 2023 by DILLARD000 Quote Link to comment Share on other sites More sharing options...
