JVC AFTERMARKET INSTALL NEED HELP
What brand of harness do you have? The instructions for your harness should tell you which wire is VSS coming out of the harness.
Also if you are not using a harness (yikes) let me know, I can check the wiring diagrams.
Lastly, VSS is not used for positioning of the satellites. It just sends a signal when the vehicle is moving which helps some nav units determine your position.
I also could use a little help on this, I am in the process of installing a Pioneer AVIC-700BT and need to know where the speed sensor wire is. I didnt have factory Nav so theres nothing in the factory harness i can tap in to..i don't think...
also any tips on finding the Ebrake sensor and easiest way to tap into the reverse lights would be sweet!
Sorry I can't helpguys, I couldn't find the VSS wire in the wiring diagrams I had. I didnt print out absolutely everything.
I found the VSS from the instructions in my harness: The overpriced AXXESS AFDI-THX-01. I also had factory Nav.
Lastly, I'm using the Pac TR7 trigger for video bypass, so I never needed to find the E-brake wire...
