2011 Edge Cooling Fans not running
I have a 2011 Edge with the 3.5L V6 and neither cooling fan is running, either with the AC in MAX or when the car gets up to normal temp.  This is obviously causing it to try to overheat when the car is not moving, and the AC doesn't blow very cold unless the car is in motion.  I know the fans fail, and the controller sometimes fails.  Question is in troubleshooting.  I will have to take part of the air box off to get to the connector for the fan controller, but when I have it off I assume that I should have 12V going to the controller?  And then have 12V coming out of the controller would tell me that it is good and it's just the fans that have failed?  If I don't have 12V, assuming that I should, going to the controller, what should I look for upstream of it?  I have no issue replacing the parts, but I don't really want to spend money for the fun of it :)  Thanks in advance, and if I'm incorrect about that could you let me know what I should be looking for?
Multi-model diagnostic procedure and Edge-specific supporting documents to address your Edge's cooling fan issue...
Document download links>
Pinpoint Test KN - Variable Speed Electric Cooling Fan - Powertrain Control-Emissions Diagnosis Manual.pdfFetching info...
COOLING FAN MODULE - Without Trailer Tow - Wiring Diagram - 2011 Edge Workshop Manual.pdfFetching info...
COOLING FAN MODULE - With Trailer Tow - Wiring Diagram - 2011 Edge Workshop Manual.pdfFetching info...
Battery Junction Box (BJB) - Illustration - 2011 Edge.pdfFetching info...
Battery Junction Box (BJB) - Fuse & Relay Listing - 2011 Edge.pdfFetching info...
POWERTRAIN CONTROL MODULE (PCM) - Connector C175B Details - 2011 Edge.pdfFetching info...
POWERTRAIN CONTROL MODULE (PCM) - Connector C175B Location - 2011 Edge.pdfFetching info...
COOLING FAN MODULE - Connector C1554 Details - 2011 Edge.pdfFetching info...
COOLING FAN MODULE - Connector C1554 Location - 2011 Edge Workshop Manual.pdfFetching info...
Air Cleaner - Removal and Installation - 2011 Edge Workshop Manual.pdfFetching info...
Intake Air System Components - Exploded View Enhanced Image - 2011 Edge-MKX Workshop Manual.pdfFetching info...
Intake Air System Components - Exploded View - 2011 Edge-MKX Workshop Manual.pdfFetching info...
Cooling Fan and Shroud - Removal and Installation - 2011 Edge Workshop Manual.pdfFetching info...
Cooling Fan and Shroud - R&I Enhanced Image - 2011 Edge Workshop Manual.pdfFetching info...
Cooling Fan and Shroud - R&I Enhanced Connectors Illustration - 2011 Edge Workshop Manual.pdfFetching info...
Good luck!
Edited by Haz
Thanks for the references.  My fan controller only has 1 out that splits to both fans.  When I looked at it I didn't have any power going in to the controller.  So in frustration I gave the top of the fuse block a thump and the fans both came on.  Now it is intermittent, sometimes they run as they should and sometimes they don't.  And further messing with the fuse block don't seem at have any effect. Any ideas?  Also, looking at the wiring diagram, I don't see any input from the PCM to the fan controller on the vehicle.  I have a 2 wire input and a 2 wire output to the fans, and that is all that I see.
  • 11 months later...
On these older Gen 1 & 1.5 (2007 to 2014), most of the time fan issues are resolved with a new fan module. It comes as a set, 2 fans and the controller. And always go for Motorcraft because of the many stories of stories on this forum when aftermarket fan modules just don't work correctly.
If the tempature guage is working on the dash, would that mean it is probably working to tell fans to turn on but controller is not reacting to the signal? That same failure to turn on fan when AC is turned on would apply I assume. That is the easier fix. Its a shame you have to pay arm and a leg for a part that will work( motorcraft) over 1year( I hope)
Expand
So if I pay $241.00 for the OEM instead of $28.00 it will work?
Expand
Try a search here and Google and you'll find an abundance of reports confirming that none of the 3rd party offerings work - another option would be to take a chance and try another 3rd party unit and report back.
Edited by 1004ron
