pwgustafson Posted August 24, 2023 Report Share Posted August 24, 2023 I have a 2014 edge sel with the 4” non touch sync radio. I’ve always used Bluetooth with no issues. But lately they’ve been getting worse. Last month or so when I start my car up it’s sort of garbled for about the first 5 seconds, like it got behind and is skipping ahead too fast to catch up or something weird. But Bluetooth has always worked fine otherwise. You listen to your streaming and when a call comes it automatically switches to phone mode. Presto easy. BUT NOW…. when I connect to my car, the audio streaming works as usual but when I go to use phone mode it says “Bluetooth phone disconnected.” But it’s literally connected to Bluetooth right now streaming audio so i don’t understand what’s the issue. I’ve reset sync in the advance settings menu. I’ve deleted and reset my Bluetooth and network connections on phone. Any other ideas????? So weird! Quote Link to comment Share on other sites More sharing options...
pwgustafson Posted September 12, 2023 Author Report Share Posted September 12, 2023 No ideas yet? my regular Bluetooth streaming function came back yesterday. Still wondering if anybody else has similar issues ever or thoughts on what would cause something like that? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 12, 2023 Report Share Posted September 12, 2023 I have SYNC 1 in my 2012 Fusion, and SYNC 1.1 in my 2015 Fusion (should be the same as yours). I had to be sure they were both updated to a mid level like version 4.4 (not the latest, as it disables specific functionality I use, the mic for Hey Google/Siri and commands on the phone), but I still have to either pull the fuse for SYNC (not easy on either Fusion), or pull the battery for a few minutes, then SYNC works like it should for 4-6 months or so. Sometimes it slightly glitches and can be cured with turning off the car, opening a door, and starting again. Quote Link to comment Share on other sites More sharing options...
