madmedic446 Posted August 14, 2023 Report Share Posted August 14, 2023 Where do I find the fuel pressure regulator on this car?? (Also... What should my static, and idling fuel pressure be?) The only thing I have found online mentions a "fuel TANK pressure sensor" Is that what regulates the pressure in the fuel injection system? Is the regulator on this car part of the fuel pump, itself? There is nothing under the hood. Just a quick connect fuel line, attached directly to the fuel rail.... Fuel rail has nothing other than the injectors. (no schrader fittings, or sensors). I am chasing a problem with both banks running rich, after replacing bad injectors. Quote Link to comment Share on other sites More sharing options...
