fairlaniac Posted August 14, 2023 Report Share Posted August 14, 2023 Last month I got a P1450 code on our '17 Edge 2.0 Ecoboost. @ 75,000 miles. I replaced the purge valve and worked fin until yesterday when the same P1450 code came up. I see all kinds of responses across the web but nothing on a repeat code. Any ideas other than a second Purge Valve? Thanks! Quote Link to comment Share on other sites More sharing options...
lildisco Posted August 14, 2023 Report Share Posted August 14, 2023 Did you use OEM? I had an after market one that lasted a few months before needing replaced. 1st one was after market, 2nd was OEM. 3+ months on the OEM. 1 Quote Link to comment Share on other sites More sharing options...
fairlaniac Posted August 15, 2023 Author Report Share Posted August 15, 2023 It was not OEM. I'll test this one first. If it is not the purge valve, I'll need to figure what else it could be? Thanks, Quote Link to comment Share on other sites More sharing options...
lildisco Posted August 15, 2023 Report Share Posted August 15, 2023 Usually the purge valve, but I believe that there's a vent somewhere in the gas tank full tube. I'm not 100% sure. Quote Link to comment Share on other sites More sharing options...
Haz Posted August 16, 2023 Report Share Posted August 16, 2023 From the 2017 Ford Powertrain Control/Emissions Diagnosis Manual, a multi-model/multi-engine diagnostic reference... Document download link> PINPOINT TEST HX - EVAPORATIVE EMISSION (EVAP) SYSTEM AND MONITOR.pdf If you progress toward undertaking the many circuit tests in the Pinpoint Test HX diagnostic procedure, I can provide Edge-specific connector details and location illustrations, and wiring diagrams. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
fairlaniac Posted August 16, 2023 Author Report Share Posted August 16, 2023 One month old Dorman purge valve is stuck open. A new $212 Ford valve to be picked up tomorrow. Thanks! 1 1 Quote Link to comment Share on other sites More sharing options...
Praetorian Posted March 14, 2024 Report Share Posted March 14, 2024 Just bought a 2015 edge titanium awd with 114k on it. Was going good for a week or so until the check engine light came on but with no noticeable problems. Ran the scanner and got P1450 and found out about only replacing the purge valve instead of the whole harness, hoping to save $125 on the fix. Took off the old purge valve and tested it anyways and it seemed fine but I installed the new one from amazon along with a new hose. Code P1450 stayed but then it added code P0443 along with it. Do I try replacing the vapor canister solenoid, or the vapor canister with a new solenoid, or just bite the bullet and get the new purge valve vapor harness? All of the above? If I need a new vapor canister, do you know where I can find one for less than $100? Thanks Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 14, 2024 Report Share Posted March 14, 2024 8 hours ago, Praetorian said: Just bought a 2015 edge titanium awd with 114k on it. Was going good for a week or so until the check engine light came on but with no noticeable problems. Ran the scanner and got P1450 and found out about only replacing the purge valve instead of the whole harness, hoping to save $125 on the fix. Took off the old purge valve and tested it anyways and it seemed fine but I installed the new one from amazon along with a new hose. Code P1450 stayed but then it added code P0443 along with it. Do I try replacing the vapor canister solenoid, or the vapor canister with a new solenoid, or just bite the bullet and get the new purge valve vapor harness? All of the above? If I need a new vapor canister, do you know where I can find one for less than $100? Thanks I wouldn't trust one bought from Amazon. Avoid overfilling the gas tank - first click, stop filling. Quote Link to comment Share on other sites More sharing options...
Haz Posted March 14, 2024 Report Share Posted March 14, 2024 From the 2015 Ford Powertrain Control/Emissions Diagnosis Manual, a multi-model/multi-engine diagnostic reference... Document download link> Pinpoint Test HX - EVAP System and Monitor- 2015 Ford PC-ED Manual.pdf Good luck! 1 2 Quote Link to comment Share on other sites More sharing options...
